Firmware V1.2.1
A release date? An update? Different versions? ... keep you informed.
Firmware V1.2.1
Postby warumnix » Tue Aug 20, 2013 4:01 pm
Hi All:)
The new firware V1.2.1 is now available with the following changes:
1. Add MuMuDVB 1.7.1 to support CAM
2. Add loop back address 127.0.0.1
3. Update DVBlast to the latest version 2.2
4. Fix bug in time & date settings,support daylight saving time
at the moment you can only update through SD card, the WUI update is not ready yet, we will post to let you know once it's ready, thank you.
Click the link to download directly -->
http://www.tbsdtv.com/download/document/tbs2900/tbs-moi-dvb-s2-streaming-box-2900-firmware_v1.2.1.zip
Your test reports & suggestions are more than welcome ;)
warumnix
Re: Firmware V1.2.1
Postby Traveler » Tue Aug 27, 2013 12:37 am
After running MuMuDVB on MOI Box with Firmware 1.2.1 I get segmentation fault, below is full log:
# mumudvb -d -c /home/mumudvb/Tuner2-HotBird.conf
MuMuDVB Version 1.7.1
 --- Build information ---
Built with CAM support.
Built without transcoding support.
Built with ATSC support.
Built with ATSC long channel names support.
Built with support for DVB API Version 5.
Originally based on dvbstream 0.6 by (C) Dave Chapman 2001-2004
Released under the GPL.
Latest version available from http://mumudvb.braice.net/
Project from the cr@ns (http://www.crans.org)
by Brice DUBOST (mumudvb@braice.net)
Info:  Main:  Full autoconfiguration, we activate SAP announces. if you want to deactivate them see the README.
Info:  Main:  Full autoconfiguration, we activate PAT rewritting. if you want to deactivate it see the README.
Info:  Main:  Full autoconfiguration, we activate SDT rewritting. if you want to deactivate it see the README.
Info:  Main:  Full autoconfiguration, we activate sorting of the EIT PID. if you want to deactivate it see the README.
Info:  Main:  ========== End of configuration, MuMuDVB version 1.7.1 is starting ==========
Info:  Autoconf:  The autoconfiguration auto update is enabled. If you want to disable it put "autoconf_pid_update=0" in your config file.
Info:  Main:  Streaming. Freq 12596000
Info:  Tune:  Using DVB card "TurboSight TBS 2991 DVBS/S2 frontend" tuner 0
Info:  Tune:  Tuning DVB-S to Freq: 1996000 kHz, LO frequency 10600000 kHz Pol:V Srate=27500000, LNB number: 4
Info:  Tune:  LNB voltage 13V
Info:  Tune:  DISEQC SETTING SUCCEDED
Info:  Tune:  FE_STATUS:
Info:  Tune:       FE_HAS_SIGNAL : found something above the noise level
Info:  Tune:       FE_HAS_CARRIER : found a DVB signal
Info:  Tune:       FE_HAS_VITERBI : FEC is stable
Info:  Tune:       FE_HAS_SYNC : found sync bytes
Info:  Tune:       FE_HAS_LOCK : everything's working...
Info:  Tune:  Event:  Frequency: 12596000 (or 8604000)
Info:  Tune:          SymbolRate: 2848000
Info:  Tune:          FEC_inner:  2
Info:  Tune:  Bit error rate: 67108863
Info:  Tune:  Signal strength: 33975
Info:  Tune:  SNR: 4369
Info:  Main:  Card 1, tuner 0 tuned
Info:  Autoconf:  Autoconfiguration Start
Segmentation fault
Traveler
Return to Announcements
Users browsing this forum: No registered users and 14 guests
