SergioDanielG wrote:im85288c wrote:Thank you very much, following your guide I have finally succeeded in updating to the latest firmware
Now, I also have an issue of HOW to configure Vdr for a sky uk setup. I only have one dish and the diseq settings are confusing...
If you have only one dish with one lnb selec diseqc 1.0 and port 1, then scan.
Regards
Thank you SergioDanielG, I followed your instructions and made some decent progress...however I think (and this is using v2.02) there is a bug with the scan function of VDR against the Eutelsat 28.2 satellite. After completing a scan of the satellite it only put about 20 channels into channels.conf and also they are being output into this file in a format that does not allow me to create/download someone else's channels.conf to use instead. I confirmed this by ssh into the moi box and running the scan command myself such as: scan -o vdr -v /usr/share/dvb/dvb-s/Eutelsat\ 28A,\ Astra\ 1N,2A,2F
> /etc/vdr/channels.conf which
Does find all of the channels but the output is what I call standard and cannot be used by VDR on the MOI.
If you scan using the button "scan channels" the channels in channels.conf look like this:
Channel 4;BSkyB:12265:h
C34M2O35S0:S28.2E:27500:2315:2316=eng,2317=NAR:2318:0:9211:2:2029:0
C34M2O35S0:S28.2E:27500:2327:2328=eng:2329:0:9212:2:2029:0
However when this is done by the scan command as above (which retrieves all my channels) the output is like:
Channel 4;BSkyB:12265:h:S28.2E:27500:2315:2316=eng,2317=NAR:2318:0:9211:2:2029:0
The part highlighted in bold is different and from what I have read it is not correct format for numbers to follow the polarisation...I would not really mind if it scanned all my channels...but something is really strange here.
I tried this on two separate MOI boxes and experienced the same problems.
It's a shame as VDR performance on XBMC seemed to be very good, any help is much appreciated
