Update: software v1.0.1 for MOI+
A release date? An update? Different versions? ... keep you informed.
Postby warumnix » Thu Aug 07, 2014 4:53 pm
Hi All,
Software (system, u-boot, kernel) for MOI+ has been updated to v1.0.1 with the following improvements:
1. Add driver to support TBS6984
2. Add "auto-stream" function
When MOI+ starts, it will scan and find all of the MOI+ 's in the same local network, and then when you start Tvheadend in MOI+ , the channels received by all of the MOI+'s will be listed in Tvheadend and streamed to the Android devices, which are in the same local network and with "multi.apk" installed.
"multi.apk" can be downloaded from:
http://www.tbsdtv.com/download/document ... v-live.apk
3. Add guides on the UI for:
"How to configure Tvheadend for DVB tuner"
and
"How to update MOI+"
warumnix
Return to Announcements
