Encrypted channels
Encrypted channels
Postby putz182 » Tue Oct 17, 2017 1:36 am
Hi, I bought my MOI box four years ago in which I've faced a sad reality. I could only use MOI with an external Oscam server. I have a paid subscription but the provider box is really bad. I tried until I found that Oscam was not compatible with my local provider. I just got really frustrated and retired my MOI box. Recently I just exchange Sat provider and just want to use MOI system again. Since then, I'm lost! Can anyone please, point me a base tutorial on how to configure an Oscam server, in which, I can be able to share to MOI?
putz182
Re: Encrypted channels
Postby steven » Tue Oct 17, 2017 10:54 am
You can have a look at this guide :
viewtopic.php?f=86&t=10049
Postby putz182 » Wed Oct 18, 2017 9:33 pm
Hi Steven, thanks!
Where I can found more info about Oscam?
http://www.streamboard.tv/ Seems to be off.
Can I buy a local card reader?
Where do I find my card info like, voltage, frequency?
In the Oscam config, for instance, what does the key mean?
[necamd]
key -> What is this supposed to be?
I'm really sorry to bother with so many questions but my last purchase was extremely frustrated. I must be sure that it will work with my local provider.
For example, N3 is really difficult because the need a box key which is inside an BGA chip. I'm having trouble to find again that kind of info and if I should keep going.
putz182
Postby putz182 » Wed Oct 25, 2017 7:14 pm
Any help?
putz182
Postby xiaocao » Thu Oct 26, 2017 6:07 pm
hi ,
The [newcamd] section
key = DES key
default key for newcamd client encryption, default:none
example: key = 0102030405060708091011121314
port = port[{DES key}]@CAID[:provid][,provid]...[;port[{DES key}]@CAID[:provid][,provid]...]...
TCP port/DES key/CAID/provid definitions, default:none
example: port = 10000@0100:100000;20000{0102030405060708091011121314}@0200:200000,300000
Each CAID requires a separate port. If you don’t specify a DES key for a port, the default DES key will be used.
serverip = IP address
bind newcamd service to specified IP address, default:all
allowed = IP address|IP address range[,IP address|IP address range]...
newcamd client connections allowed from, default:none
example: allowed = 127.0.0.1,192.168.0.0-192.168.255.255,::1
keepalive = 0|1
0 = disable newcamd keepalive modus, default:0
mgclient = 0|1
1 = provide share information of all available CAIDs and provider IDs to mgcamd clients, default:0
please see more details from :
https://www.gsp.com/cgi-bin/man.cgi?sec ... oscam.conf
best regards!
xiaocao
Return to General discussion
