Dead Nand ?
Dead Nand ?
Postby starsurfer » Sun Feb 14, 2021 5:43 am
Get this Error from an other UART1 maybe ?
Normal UART is Dead and didnt show anything.
How can i get the Moi back to life ?
Greets StarSurfer
Nand Check Sum Error
SD Init Error
Uart negotiation Error
Insert an OTG cable into the connector!
Enumeration TimeOut Error
starsurfer
Re: Dead Nand ?
Postby gobi2000 » Thu Dec 09, 2021 3:29 am
Please hepl my have i's problem:
have send comand upgrade firmware for mmc
Prepare a formatted micro SD card, copy the file “MOI290-fs.bin” into it, insert it into the SD card slot on MOI, power on MOI, “Enter” uboot quickly (within about 3 seconds after MOI is powered on) and input the command lines:
setenv loadmmcfs 'fatload mmc 0:1 40000000 MOI2900_fs.bin'
setenv updatekfs 'nand erase 50c0000;nand write.yaffs 40000000 50c0000 ${filesize}'
save
then input “re”, MOI will start to update.
MOI2900 # boot
NAND read: device 0 offset 0xc0000, size 0x400000
Main area read (32 blocks):
 4194304 bytes read: OK
NAND erase: device 0 offset 0x48c0000, size 0x400000
Erasing at 0x4ca0000 -- 100% complete.
OK
NAND write: device 0 offset 0x48c0000, size 0x400000
Main area write (32 blocks):
 4194304 bytes written: OK
NAND erase: device 0 offset 0x50c0000, size 0xaf40000
Skipping bad block at  0x06320000
Skipping bad block at  0x088a0000
Skipping bad block at  0x0d760000
Skipping bad block at  0x0fe80000
Erasing at 0xffe0000 -- 100% complete.
OK
get_format
-------- 0 --------
Wrong Image Format for bootm command
ERROR: can't get kernel image!
MOI2900 #
gobi2000
Return to General discussion
