eesdil wrote:Is there anybody who knows how to setup moi to watch encrypted channels? In the advertisement it is quite easy... You are just plugging your paid card in and it works... Looks like it is not that easy as after 2 weeks it is still not working. Including speaking with TBS support.
Is it really not possible to configure it or just me who is not able to make it working?
Anyway I would really appreciate if somebody had any good idea how to set it up.
Hey, be patience, please.
Ok, now I see Your config. That never be working like a 'sharing server'.
How You want setup clear Ecm with CAM module? You need to create any API for switching channels and sending data to oscam (based on dvbapi), or use (maybe) camd.socket option with TVHeadend.
(I never tried that and I'm very busy up to end of next week, try tvheadend forum, camd.socket, oscam with ci - gooogle).
I think, You understand CZ/SK language, when You're using a Skylink card, so just learning, start here: http://www.cssf.cz/showthread.php?39853 ... rtu-IRDETO
And TVheadend: https://www.lonelycoder.com/redmine/boa ... opics/4502
And some thread about oscam and CI module.
I'm really not sure, if using camd.socket and tvheadend will be working as well.
Newcamd options:
CAM module can't working as sharing server, needed by TVheadend - newcamd option.
You have these possibilities:
1. Use usb phoenix, with options of switching to 6MHz. Or any smargo reader, directly with Your card, without CAM module.
You will need some IDs add to Your config file, Your card is pairing with CAM module, as sure.
2. CAM module need a CAT, PMT pids (minimal) for init stream, not only ECM/EMM pid, what is sending from TVheadend.
Also, I don't know as working parsing EMM data for 0624 id in TVheadend.
3. MOI:
In technical documentation You have, that CI support is only with Mumudvb and DVBlast (dvblast22).
So, isn't true, that CI will be working with TVheadend, what You're prefering.
4. You did'n wrote, what type of Irdeto card You have (revision), also type of Your CAM module.
If You have a CAM Security+ based Irdeto CAM, I don't know as will passing data for dvr (blocked recording).
Ok, You can try:
-close oscam
-CI module must be out
- use 'scan-s2' for scanning Your channels
-insert CI module
-start oscam
- use 'szap-s2' for switch channels and monitor oscam over Webif (but dvb-app utils are linked with their modules.... You will see).
BTW - all is possible (look at picture - nCam HD CI+ with standard .m3u playlist + VLC), but not yet for distribution, maybe will be another way...
