i see difference in automatic and manual writing:
automatic looks:
NAND write: device 0 offset 0x50c0000, size 0xaf40000
Input block length is not page aligned
Data did not fit into device, due to bad blocks
183762944 bytes written: ERROR
manual:
nand write.yaffs c0008000 50c0000 ${filesize}
NAND write: device 0 offset 0x50c0000, size 0x2a4a940
Bad block at 0x52e0000 in erase block from 0x52e0000 will be skipped
Bad block at 0x5fc0000 in erase block from 0x5fc0000 will be skipped
Writing data at 0x7a02000 -- 100% complete.
44345664 bytes written: OK
size is different in automatic why?
can you post me your printenv, please.
i'm sorry to bother you with that, i got this unit from previous developer (and was like that, nonworking, atleast now it works after manual write).
