MOI - DVR to USB HDD/Stick or MicroSD Card
Postby marcelp1 » Wed Oct 23, 2013 11:00 pm
MOI is my first Linux BOX I have actually access to root :) so no window that I can click and have
my USB HDD/Stick or MicroSD Card automatically ready for use and record programs to it.
I would like to know if it is at all possible to record programs do USB HDD (with own external power or no power)
USB Sticks and the MicroSD card that has got the slot at the back.
If so what are the requirements file system etc. and if someone could post either their setup or
guide for beginners on how to achieve it.
marcelp1
Re: MOI - DVR to USB HDD/Stick or MicroSD Card
Postby updatelee » Wed Oct 23, 2013 11:19 pm
My tune-s2/demux app are simple enough they should cross compile fine. They are console apps. Google my Nick and you'll find my bitbucket site
Postby marcelp1 » Thu Oct 24, 2013 12:35 am
S looking at https://bitbucket.org/updatelee
I have found:
v4l-updatelee updated 2013-10-14
My devel tree based off v4l media_tree
updateDVB updated 2013-10-14
updateDVB is an all in one Linux application supporting spectrum scan and IQ plot for various tuners, tuning and parsing of the stream as well as streaming the TS to other applications.
tune-s2 updated 2013-10-04
tune-s2 is a simple tuning only application, thats all it does, tune then wait.
demux updated 2013-08-27
demux specific pids from an already tuned adapter
Now I can see that for you Linux is a daily bread, for me it is learning curve and I just started, so could you be more specific about (croscompile????):
- if recording from TVHeadend, can it be done to USB HDD/Stick or MicroSD Card or are there any restriction?
- what are the requirements for the partition type [mbr / gpt] or file system [afat, fat32, ntfs, ext4, xfs ....] (how should I format the HDD/Stick/mSD Card?
- do I just plug the USB HDD/Stick or MicroSD Card in the back of the MOI box and use SSH to the box and be able to configure it from the (SSH shell )
or do I need to prep (partition type / file system) beforehand?
marcelp1
Postby updatelee » Thu Oct 24, 2013 4:04 am
I don't own an moi but I used todo devel for Dreambox so I have cross compiled tune-s2 and my demux app before. Cross compiling is the compiling of apps on one arch for running on another. Ie compiling using an x64 arch to compile an app to run on mips .
I think there is a thread here about how to set this up. Can't rem and I'm not home for two weeks to check
Tvheadend is for streaming only I believe, I don't use it either so I don't know.
I'm more interested in stream analysis. So that's where I focus most of my devel time.
Postby gfi » Wed Nov 13, 2013 2:40 am
marcelp1 Wrote:MOI is my first Linux BOX I have actually access to root :) so no window that I can click and have
filesystem - ext2, ext3, vfat (fat32)
What You need to record? You wrote only "I need record a program".
All applications, included in MOI have possibilities of http streaming. So, there's no problem to record.
- dvblast or other multicast streaming application = use udpxy application.
- tvheadend, getstream, astra have already support for http streaming.
So, why use any external dvr and demux handlers.
Everything You need is create script/app (I have something too, for record from other boxes, not local only).
Or use only commandline (for newbies) over ssh.
Simply wget ....
More at: viewtopic.php?f=94&t=8676
gfi
Return to General discussion
