[ Moderator Control Panel ]
by lordlucan » Sun Mar 30, 2014 6:32 pm
I am hoping someone can help me. I want to subscribe to "My-hd" which has a CAM CI option available.
Will this work with my MOI DVB-S2 either using OSCAM, DVBBLAST or MUMUDVB?
It uses Irdeto CI + 1.3 Unified Client CAM, it supports Cloaked CA and Softcell.
Or should I just forget about this subscription???
Any advice would be appreciated.
lordlucan
by ahmedramze » Thu May 22, 2014 1:21 am
I posted it too many time , no one support us.
why they put the PCMCIA slot even no use for it.
im use Mouse card reader for normal Irdeto and viacess , but problem with chip peering of My-HD the use Secure CAM that can not work with any card reader , im try to get USB to PCMCIA adapter to use it with CCCAM server but no way.
I will have old laptop with PCMCIA port I will install Ubuntu with CCCAM and test it if its work will report it
ahmedramze
Return to General discussion
