trouble witch my TBS MOI on Tuner A (2990)
Postby vladi2010 » Thu Sep 04, 2014 5:37 pm
Hi´m Andreas form Germany
I have trouble witch my TBS MOI on Tuner A (2990) science I have buy it about 8 Month ago.
Tuner B (2991) works perfect.
I use Tvheadand and XBMC
The problem is:
All Transponders are not Stabile on Tuner A, the Transmission is Broking every view second.
Its not a problem from the Satelitdich because I have cross the Cable and the problem stay on Tuner A
I have still testes the Dish witch another DVB-S Receivers like Dreamox, Ariva and else Receivers, they all works Perfect.
I Think the is something wrong with Tuner A
What can I do now ?
Her is a short cut of Tvheadens Protocol:
Sep 04 14:29:04.020 TS: TurboSight TBS 2990 DVBS/S2 frontend/ASTRA 1: 11,361,750 kHz Horizontal (Astra 19)/ZDF HD: Transport error indicator
Sep 04 14:29:04.020 TS: TurboSight TBS 2990 DVBS/S2 frontend/ASTRA 1: 11,361,750 kHz Horizontal (Astra 19)/ZDF HD: H264 @ #6110: Continuity counter error
Sep 04 14:29:04.020 TS: TurboSight TBS 2990 DVBS/S2 frontend/ASTRA 1: 11,361,750 kHz Horizontal (Astra 19)/ZDF HD: MPEG2AUDIO @ #6123: Continuity counter error
Sep 04 14:29:04.025 TS: TurboSight TBS 2990 DVBS/S2 frontend/ASTRA 1: 11,361,750 kHz Horizontal (Astra 19)/ZDF HD: AC3 @ #6122: Continuity counter error
Sep 04 14:29:04.026 TS: TurboSight TBS 2990 DVBS/S2 frontend/ASTRA 1: 11,361,750 kHz Horizontal (Astra 19)/ZDF HD: MPEG2AUDIO @ #6121: Continuity counter error
Sep 04 14:29:04.041 TS: TurboSight TBS 2990 DVBS/S2 frontend/ASTRA 1: 11,361,750 kHz Horizontal (Astra 19)/ZDF HD: MPEG2AUDIO @ #6120: Continuity counter error
Sep 04 14:29:04.087 TS: TurboSight TBS 2990 DVBS/S2 frontend/ASTRA 1: 11,361,750 kHz Horizontal (Astra 19)/ZDF HD: TELETEXT @ #6130: Continuity counter error
Sep 04 14:29:04.380 TS: TurboSight TBS 2990 DVBS/S2 frontend/ASTRA 1: 11,361,750 kHz Horizontal (Astra 19)/ZDF HD: DVBSUB @ #6131: Continuity counter error
Sep 04 14:29:04.395 TS: TurboSight TBS 2990 DVBS/S2 frontend/ASTRA 1: 11,361,750 kHz Horizontal (Astra 19)/ZDF HD: H264 @ #6110: Corrupted PES header
Sep 04 14:29:05.003 TS: TurboSight TBS 2990 DVBS/S2 frontend/ASTRA 1: 11,361,750 kHz Horizontal (Astra 19)/ZDF HD: H264 @ #6110: Continuity counter error, 1094 duplicate log lines suppressed
Regrades
Andreas
vladi2010
Re: trouble witch my TBS MOI on Tuner A (2990)
Postby TUISTERa » Mon Feb 16, 2015 5:27 pm
I think this is normal for this device. My tuner A died an year ago and never worked again. Tuner B work perfectly... Cables are fine. You can check if cables are ok...
TUISTERa
Return to General discussion
