CAM Module
CAM Module
Postby putz182 » Fri Dec 20, 2013 8:44 pm
I now see that I bought MOi without enought reading. I just got my MOI but I am stucked.
Which CAM Module should I buy? NagraVision3 - $ky - BR
putz182
Re: CAM Module
Postby steven » Fri Dec 27, 2013 3:12 pm
Here is the older list which we have already tested.
viewtopic.php?f=33&t=1420
In our online shop all the CAM is supported.
Re: CAM Module
Postby putz182 » Sun Dec 29, 2013 7:25 am
Ok, I thank you for the help, but I have lot of troubles!
I read that TVHeadend does not work with CAM module! If that is correct, I need to go to Oscam!
Since my card is a NDS GL54 - Red Card, it seems that is no way to read the card until now! I can't find any more readings... Is that correct? Does my MOI will be used as a paper weight?
putz182
Return to Install and setup
