vsftpd [Linux package]
Postby gfi » Sat May 04, 2013 11:46 am
Version 2.3.2 with full root access.
(You maybe need adapt config file (/etc/vsftpd.conf) to Your home network)
Note: Tou need to have installed an opkg manager (viewtopic.php?f=95&t=8485)
Over ssh type:
opkg install vsftpd-moi.ipk
Vsftpd will starting directly after instalation.
You can control instaled package with command:
opkg list
You can remove package with command:
opkg remove Moi-package-vsftpd
If someone need a version 2.3.4, let me know.
Edit: vsftpd is already included in higher FW version.
gfi
Re: vsftpd [Linux package]
Postby someguy » Thu Sep 12, 2013 10:58 pm
"The selected attachment does not exist anymore."
Please fix it !
someguy
Postby gfi » Wed Nov 13, 2013 1:34 am
someguy Wrote:"The selected attachment does not exist anymore."
Please fix it !
vsftpd is in higher version of FW, attachment deleted.
gfi
Return to Software
