HD Channels
HD Channels
Postby putz182 » Sun Dec 29, 2013 10:12 am
Can't find any HD channels? Added all multi and nothing? Only SD!
What am I missing?
putz182
Re: HD Channels
Postby updatelee » Sun Dec 29, 2013 2:19 pm
Tune a transponder that has HD content
Re: HD Channels
Postby putz182 » Mon Dec 30, 2013 5:23 am
updatelee Wrote:Tune a transponder that has HD content
Yes, i did! Actually, there are some channels with no name!
But none labeled as HD...
Does i need to set a special configuration for the tunner?!
Intelsat 11 43W
putz182
Re: HD Channels
Postby updatelee » Mon Dec 30, 2013 10:06 am
Not really sure what you mean by 'labeled has HD'
Look on lyngsat and see what channel should be HD, not tune that transponder and scan. Now can you watch that channel ? congrats its HD. it has to be. You can only watch what the provider sends down, if they send HD it'll be HD. If they send SD, then its SD.
If you cant for some reason, post the channel name, vpid, apid, pcr etc and freq/polarity/symbol rate and we'll try and help
Return to Software
