MuMuDvb - Configuration
Postby Streamer » Sat Feb 01, 2014 2:03 am
I have problem with configuration MuMuDvb.
In the first step I run "scan" and I have got :
Code: Select all
4fun.TV:10719:v:0:27500:163:92:4404
4fun.TV                  (0x1134) 01: PCR == V   V 0x00a3 A 0x005c (pol) TT 0x0204
Szap :
Code: Select all
zapping to 34 '4fun.TV':
sat 0, frequency = 10719 MHz V, symbolrate 27500000, vpid = 0x00a3, apid = 0x005c sid = 0x1134
status 1f | signal 86a7 | snr df91 | ber 03ffffff | unc 00000000 | FE_HAS_LOCK
status 1f | signal c69b | snr 5709 | ber 03ffff00 | unc 00000000 | FE_HAS_LOCK
status 1f | signal c6db | snr d39f | ber 00000000 | unc 00000000 | FE_HAS_LOCK
MuMuDvb.conf :
Code: Select all
card=0
freq=10719
pol=v
srate=27500
common_port=1234
multicast_ttl=10
ip=46.41.XXX.XXX
#ip=127.0.0.1
port=1234
name=4Fun.TV - Stream
service_id=92
pids= 4404
#cam_pmt_id = 4404
On 46.41.XXX.XXX netcat :
Code: Select all
nc -l -p 1234
Code: Select all
MuMuDVB Version 1.7.2
 --- Build information ---
Built with CAM support.
Built with SCAM support.
Built without transcoding support.
Built with ATSC support.
Built with ATSC long channel names support.
Built with support for DVB API Version 5.2.
Originally based on dvbstream 0.6 by (C) Dave Chapman 2001-2004
Released under the GPL.
Latest version available from http://mumudvb.braice.net/
Project from the [email protected] (http://www.crans.org)
by Brice DUBOST ([email protected])
Info:  SAP:  Sap announces will be sent
Info:  Main:  ========== End of configuration, MuMuDVB version 1.7.2 is starting ==========
Info:  Main:  Streaming. Freq 10719000
Info:  Tune:  Using DVB card "TurboSight TBS 2990 DVBS/S2 frontend" tuner 0
Info:  Tune:  Tuning DVB-S to Freq: 969000 kHz, LO frequency 9750000 kHz Pol:V Srate=27500000, LNB number: 0
Info:  Tune:  LNB voltage 13V
Info:  Tune:  DISEQC SETTING SUCCEDED
Info:  Tune:  FE_STATUS:
Info:  Tune:       FE_HAS_SIGNAL : found something above the noise level
Info:  Tune:       FE_HAS_CARRIER : found a DVB signal
Info:  Tune:       FE_HAS_VITERBI : FEC is stable
Info:  Tune:       FE_HAS_SYNC : found sync bytes
Info:  Tune:       FE_HAS_LOCK : everything's working...
Info:  Tune:  Event:  Frequency: 10719000 (or 8781000)
Info:  Tune:          SymbolRate: 27500000
Info:  Tune:          FEC_inner:  5
Info:  Tune:  Bit error rate: 67108608
Info:  Tune:  Signal strength: 30422
Info:  Tune:  SNR: 54175
Info:  Main:  Card 0, tuner 0 tuned
Info:  Main:  Diffusion 1 channel
Info:  Main:  Channel number :   0, name : "4Fun.TV - Stream"  service id 92
Info:  Main:    Multicast4 ip : 46.41.XXX.XXX:1234
And now MuMu is "frozen" and don't send any packets but streaming timer works correctly because after exit I see :
Code: Select all
^CInfo:  Main:  End of streaming. We streamed during 0d 0:02:11
Info:  Main:  Caught signal 2 - closing cleanly.
Info:  Main:  ========== MuMuDVB version 1.7.2 is stopping with ExitCode 0 ==========
Connection from MOI to 46.41.XXX.XXX is available on this port, but I also tested it on 127.0.0.1.
What is wrong ?
Best Regards
Streamer
Return to Software
