I had some additional time at my disposal, so I decided to compile the latest TVHeadend 3.9 git for the MOI DVB-S2 Streaming Box.
These builds are provided as is, are are not optimized in any way and using them is at your own risk. I can't be held responsible for any issues that may arise like bricked or unstable devices. They seemed to work fine on my MOI DVB-S2 with firmware 2.0.3, but this doesn't mean it'll work for you.
As always: before putting these files on your MOI, please make a backup of the tvheadend and oscam binaries (residing in /usr/bin and /usr/local/bin) and config-files (residing in /.hts and /usr/local/etc) before overwriting them.
Because the current TVHeadend git-version is using a new config, you'll need to convert the /.hts/tvheadend folder using the migration tool (see: https://www.tvheadend.org/boards/5/topics/9792) or start over again. Another option would be to use a Enigma2/LameDB channellist and us the lamedb2tvh script (https://bitbucket.org/picons/lamedb2tvh/src) to convert it.
The file includes the following binaries:
- OSCAM 1.2 Revision 9842 (latest git, compiled with libdvbcsa support with support for USB-readers)
- Changed tvheadend.sh script for /usr/bin for use with oscam
- TVHeadend 3.9 (latest git, compiled with libdvbcsa support)
Grab the file from here: http://shalafi.home.xs4all.nl/moi/20143 ... bs2.tar.gz
