New Oscam versions not working with MuMudvb
Postby nightshadow36 » Tue Aug 09, 2016 6:10 pm
Hello has any one come across this issue.
Old Oscam versions / Phoenix card reader / MuMudvb / TBS / = Working.
New Oscam versions / Phoenix card reader / MuMudvb / TBS / = Not working.
With the new Oscam versions it shows as the ecm as found but with MuMudvb it does not decrypt just black screen.
If any one knows the issue please let me know.
Thank you for your time.
nightshadow36
Re: New Oscam versions not working with MuMudvb
Postby xiaocao » Tue May 09, 2017 3:32 pm
1. which mumudvb and oscam version do you use ?
2. you can tell me the oscam.conf and oscam.server file .
3. you should tell me the configuration file of mumudvb.
xiaocao
Return to Off topics
