how to build TVheadend for MOI
Postby bob » Fri Apr 12, 2013 2:34 pm
Thanks to Adam from TVheadend team!
Please check this: https://github.com/tvheadend/tvheadend- ... /buildroot
bob
Re: how to build TVheadend for MOI
Postby babboy » Thu Jan 23, 2014 6:33 am
Has something changed, wanted to build tvheadend 3.6. but if I want to run it on the moi, always comes can not find tvheadend.
Firmware 2.02 is original 2.3 Mb large mine only 576KB big
babboy
Postby nwagenaar » Sat Aug 30, 2014 10:01 am
For buildroot-2014.05 use the enclosed link: http://shalafi.home.xs4all.nl/moi/config
Just rename it as .config and put it in the buildroot-2014.05 folder.
nwagenaar
Postby hatster » Mon Jul 27, 2015 5:44 pm
Is this also suitable for Moi Pro ?
thanks,
hatster
Postby nwagenaar » Wed Jul 29, 2015 4:23 pm
You could use the config as a beginning for your buildroot setup.
But you need to change the Target Options considering the MOI is using a Cortex-A8 vs the MOI Pro with a Cortex-A9.
nwagenaar
Return to Streaming box development
