TBS 6902 Query
TBS 6902 Query
Postby member91040 » Thu Sep 08, 2016 6:28 pm
Hello Team,
This is a new customer to new product tbs 6902, i have been using different cards and different brands but recently i have purchase tbs 6902 and its working well but i have few query's regarding card, i could not able to run blind scan on ebs pro and on easy blind scan, could you please solve my issue to run it on EBSpro.
I have been using tbs blind scan, its a very very good tool but few time need an EBSpro,
Request you to please look in to my query.
member91040
Re: TBS 6902 Query
Postby DVB » Fri Sep 09, 2016 6:38 am
Try to update EBSPro to latest version and if it won't help - try to replace StreamReader.dll with new version: https://sourceforge.net/projects/crazyscan/files/
TBS6902 is supported by StreamReaderEx-BDA, so it should work with EBSPro. If it is not working - that's EBSPro fault and ask author for update.
DVB
Re: TBS 6902 Query
Postby member91040 » Wed Sep 21, 2016 7:57 pm
Thanks for the reply, after updating with StreamReaderEX-BDA its woking fine.
member91040
Re: TBS 6902 Query
Postby member91040 » Tue Oct 11, 2016 5:58 pm
Could not able to run TSReader for TBS6902, Please provide the file or procedure for TS Reader
member91040
Re: TBS 6902 Query
Postby duane01098 » Thu Oct 13, 2016 6:45 pm
I use the dvbsbdasource sucessfully. Hope this helps
duane01098
Re: TBS 6902 Query
Postby member91040 » Thu Oct 13, 2016 11:21 pm
Fail to lock signal, DVB-S Compatible source, could not able to tune
member91040
