An Issue in TS stream receiving
Postby phkarmur » Fri Jan 20, 2017 3:56 pm
I have an Issue while I try to receive TS stream of Bell 82 and Dish 119 satellites.
First of all see this video: https://www.dropbox.com/s/oveswfgxawaf6u2/issue.webm?dl=0
Now I am able to get stream from other C Band satellites but those signal are not inverted and while in this case all are inverted spectral. So I am not sure what exactly problem is
And this problem is only in this card because I am able to receive stream in Prof 7500 USB
I am using latest TBS driver V1.0.0.7.
May be problem is card doesn't supports this type of signal or driver or DLL file of CrazyCat (StreamReader.dll).
Logs of StreamReader:
02:22:09 - 20/01/2017 GetSignalEx()
02:22:09 - 20/01/2017 Signal SNR = 0.000000dB BER = 10.000000
02:22:10 - 20/01/2017 Statistic()
02:22:10 - 20/01/2017 Signal Present = 1 Locked = 0
02:22:10 - 20/01/2017 Level = 0% Quality = 0%
02:22:10 - 20/01/2017 GetSignalEx()
02:22:10 - 20/01/2017 Signal SNR = 0.000000dB BER = 10.000000
02:22:11 - 20/01/2017 MISSel(0,0x00,0x00)
02:22:12 - 20/01/2017 BLScanEx(12200000,5000,0,11250000,0,0,100000,0,0x784CE2C)
02:22:13 - 20/01/2017 BLScanEx(12205000,5000,0,11250000,0,0,100000,0,0x784CE2C)
02:22:14 - 20/01/2017 BLScanEx(12210000,5000,0,11250000,0,0,100000,0,0x784CE2C)
02:22:14 - 20/01/2017 BLScanEx(12215000,5000,0,11250000,0,0,100000,0,0x784CE2C)
02:22:15 - 20/01/2017 BLScanEx(12220000,5000,0,11250000,0,0,100000,0,0x784CE2C)
02:22:16 - 20/01/2017 BLScanEx(12225000,5000,0,11250000,0,0,100000,0,0x784CE2C)
02:22:16 - 20/01/2017 BLScanEx(12241572,5000,0,11250000,0,0,100000,0,0x784CE2C)
02:22:17 - 20/01/2017 BLScanEx(12246572,5000,0,11250000,0,0,100000,0,0x784CE2C)
02:22:18 - 20/01/2017 Statistic()
02:22:18 - 20/01/2017 Signal Present = 1 Locked = 0
02:22:18 - 20/01/2017 Level = 0% Quality = 0%
02:22:18 - 20/01/2017 GetSignalEx()
02:22:18 - 20/01/2017 Signal SNR = 0.000000dB BER = 10.000000
02:22:19 - 20/01/2017 Statistic()
02:22:19 - 20/01/2017 Signal Present = 1 Locked = 0
02:22:19 - 20/01/2017 Level = 0% Quality = 0%
02:22:19 - 20/01/2017 GetSignalEx()
02:22:19 - 20/01/2017 Signal SNR = 0.000000dB BER = 10.000000
02:22:20 - 20/01/2017 Statistic()
02:22:20 - 20/01/2017 Signal Present = 1 Locked = 0
02:22:20 - 20/01/2017 Level = 0% Quality = 0%
02:22:20 - 20/01/2017 GetSignalEx()
02:22:20 - 20/01/2017 Signal SNR = 0.000000dB BER = 10.000000
02:22:20 - 20/01/2017 SetChannelExEx(12227075, 19995167, 0, 3, 11250000, 0, 0, 1, 0, 0, 0)
02:22:23 - 20/01/2017 STV091X_Search() - Search failed
02:22:23 - 20/01/2017 TBS_STV091X_Tune() : failed !
02:22:23 - 20/01/2017 Unspecified error
02:22:23 - 20/01/2017 Signal RFLevel=-34 dBm
02:22:23 - 20/01/2017 Not lock !
02:22:23 - 20/01/2017 SignalInfo()
02:22:23 - 20/01/2017 DelFilter(0)
02:22:23 - 20/01/2017 Filter with ID 0 not exists !
02:22:23 - 20/01/2017 SetFilter(8192, 0x04F4F31E, 2, 1, 0x02A13C24)
02:22:23 - 20/01/2017 filter_num=0
02:22:23 - 20/01/2017 Statistic()
02:22:23 - 20/01/2017 Signal Present = 1 Locked = 0
02:22:23 - 20/01/2017 Level = 0% Quality = 0%
So please let us know what is exactly problem and how to fix it?
Thank you.
phkarmur
Re: An Issue in TS stream receiving
Postby steven » Sun Jan 22, 2017 11:34 am
Thanks for the information for this transponder you need to use our TBS6908 or TBS5927 to receive more information you can check here :
http://www.tbsiptv.com/tbs5927-professi ... earch=5927
http://www.tbsiptv.com/tbs6908-professi ... earch=6908
Postby phkarmur » Sun Jan 22, 2017 7:51 pm
You mean TBS6905 does not supports this type of transponder, right?
phkarmur
Postby crazycat » Mon Jan 23, 2017 4:53 am
Look like usual DVB-S transponders from Dish TV 119W ? Some exotic LNB with LOF 11250MHz.
Maybe need set proper SR 20000Ks on SetChannel() ?
Postby phkarmur » Mon Jan 23, 2017 11:46 pm
I have this problem in Dish 119 and Bell 82 satellites, and both satellites have "inverted" spectral and same LOF 11250 MHz.
So I think problem is inverted signal or LOF 11250 MHz (DSS band/DirecTV).
Because I manually rounded SR to 20000 Ks but it didn't help.
phkarmur
Postby phkarmur » Wed Feb 01, 2017 5:31 pm
I am 99.99% sure its inverted spectral issue with this hardware because I checked for Galaxy 23 (C Band) satellite and I didn't get any problem with normal signal.
Please watch this video: https://www.dropbox.com/s/71ssrn9ydoqp8 ... .webm?dl=0
So please help me to get rid this problem.
phkarmur
Postby phkarmur » Tue Feb 14, 2017 3:38 am
As per your suggestion I bought TBS 6908 but I still have same issue in that card too.
You can watch this video: https://www.dropbox.com/s/uokg96gfcfglg ... .webm?dl=0
As I told you, I don't think its DSS issue its "inverted spectral" signal issue.
So please find the solution of this problem as soon as possible, I wasted so much time because of this problem. :evil: :evil: :evil:
phkarmur
Postby DVB » Thu Feb 16, 2017 8:06 am
I see that You have lock in some scenarios (when You will go throung Signal Analyzer window)
You should update EBS Pro, because You are using very old version and also check configuration. Definitely not related to Spectral Inversion.
And now you're watching 8K:
KKKKKKKK
DVB
