TBS-6220 PCI-Express compatibility issues
Postby korobass » Thu Mar 02, 2017 4:13 am
Hello all interested in pci-express compatibility issues.
I've bought recently card TBS 6220 DVB-T/T2 and was really suprised that it hasn't being recognized by hp 6300 pro based on i3.
As i had similar issue with my previous tuner card which was hauppauge wintv-hvr-1200 i just check tbs card in another pc and as i suspected it has been recognized.
However didn't know what is the exact issue with it until i found out this forum thread and figured out that there are different versions of PCI-E slots and TBS at least model that i bought is based on version 1.
Anyway i started digging around and hadn't found any resolution of my issue. Upgrading BIOS on hp 6300 didn't help.
If you have any idea what else can be done to make it working on my PC i will be much appreciated.
Below is specifications of two PC HP SFF box on which i had tried the TBS 6220 tuner.
HP 6000 Pro specification on which tuner is working:
media
    description: Low Profile Desktop Computer
    product: HP Compaq 6000 Pro SFF PC (AT492AV)
    vendor: Hewlett-Packard
    width: 64 bits
    capabilities: smbios-2.6 dmi-2.6 vsyscall32
    firmware
          description: BIOS
          physical id: 1
          version: 786G2 v02.03
          date: 10/19/2015
   Type: x1 PCI Express
   Type: x16 PCI Express 2
HP 6300 Pro specification on which tuner doesn't being recognized in PCI-E slot:
    product: HP Compaq Pro 6300 SFF (QV985AV)
    width: 64 bits
    capabilities: smbios-2.7 dmi-2.7 vsyscall32
*-firmware
          description: BIOS
          physical id: 0
          version: K01 v03.04
          date: 10/05/2016
          capacity: 15MiB
          capabilities: pci pnp upgrade shadowing cdboot bootselect edd int5printscreen int9keyboard int14serial int17printer acpi usb biosbootspecification netboot uefi
   Type: x16 PCI Express 2 x16
   Type: x4 PCI Express 2 x4
   Type: x1 PCI Express 2 x1
korobass
Re: TBS-6220 PCI-Express compatibility issues
Postby korobass » Thu Mar 02, 2017 4:16 am
I've even created separate thread on HP forum but don't expect they will release a new version of BIOS.
For reference below is the link:
http://h30434.www3.hp.com/t5/Desktop-Bo ... 025#M41174
korobass
