LibreELEC (Krypton) v8.0.1 MR
Postby vpeter » Sat Mar 25, 2017 9:37 pm
After skipped v8.0.0 here is LibreELEC (Krypton) v8.0.1 MR
vpeter
Re: LibreELEC (Krypton) v8.0.1 MR
Postby franky384 » Sun Mar 26, 2017 12:37 am
Let me be the first with a big thank you for your outstanding and continuing work !!
franky384
Postby franky384 » Mon Mar 27, 2017 9:51 pm
@ vpeter
Thanks again for this new version, it's working very well so far, but is there any way to enable the onboard ir-receiver in libreelec ?
I want to use my mce remote with it.
I have a Matrix v2.1 with buildin ir-receiver.
I used the forum search and found your posts about the ir-receiver but all links are dead, they're from 2014.
I found this in dmesg
gpio_ir_recv: Unknown symbol nsecs_to_jiffies (err 0)
LibreMATRIX:~ # modprobe gpio-ir-recv
modprobe: ERROR: could not insert 'gpio_ir_recv': Unknown symbol in module, or unknown parameter (see dmesg)
LibreMATRIX:~ # modinfo gpio-ir-recv
filename: /lib/modules/3.14.79/kernel/drivers/media/rc/gpio-ir-recv.ko
license: GPL v2
description: GPIO IR Receiver driver
alias: of:N*T*Cgpio-ir-receiver*
depends:
intree: Y
vermagic: 3.14.79 SMP mod_unload ARMv7 p2v8
franky384
Postby vpeter » Mon Mar 27, 2017 11:29 pm
True, image with kernel 3.14 doesn't have working IR (same as cubox-i from solidrun).
Download LibreELEC-imx6.arm-8.0.1-matrix-sr-3.14.tar (27-Mar-2017 15:23 166062080 bytes) file again and update with it. After that IR should work. Let me know if doesn't.
vpeter
Postby ddjpp » Mon Mar 27, 2017 11:40 pm
Peter you are the best!
ddjpp
Postby vpeter » Tue Mar 28, 2017 2:17 am
Thank you ddjpp. For everything.
vpeter
Postby franky384 » Fri Mar 31, 2017 4:10 am
vpeter wrote:Let me know if doesn't.
Sorry for my late reply, had to work.
My remote works perfect with your update, thank you !!
franky384
Postby sepinho » Fri Mar 31, 2017 3:53 pm
Fantastic work, I really appreciate it. Will update my Matrix and my Cubox-i tonight!
sepinho
Postby peterbelt » Sun Apr 02, 2017 3:06 am
Great job peter
regards,
Peter
peterbelt
Postby sepinho » Sun Apr 02, 2017 8:06 pm
On a somewhat related note: Is there a subform on the Libreelec forum for Freescale iMX6 devices. vpeter seems to be single-handedly keeping them alive, but I can't find a central resource for information concerning both my Matrixtv and my Cubox-i.
sepinho
Return to Announcements
