Two out of 16 Tuners Working
Postby lazerbeam84 » Fri Apr 28, 2017 9:46 pm
We have recently purchased three (3) MOI AMD PRO Streaming Servers with two Octa Tuner DVB-C Cards, upon arrival we have done the requisite updates to the servers and the lsdvb readout is as follows:
Code: Select all
                Version: 0.0.4
                Copyright (C) Manu Abraham
TBSECP3 driver (544:6178 6209:1) on PCI Domain:0 Bus:5 Device:0 Function:0
        DEVICE:0 ADAPTER:4 FRONTEND:0 (Turbosight TBS 6209 (Octa DVB-T/T2/C2/C(j83-a/b/c)/)
                 FE_QAM Fmin=47MHz Fmax=862MHz
        DEVICE:0 ADAPTER:0 FRONTEND:0 (Turbosight TBS 6209 (Octa DVB-T/T2/C2/C(j83-a/b/c)/)
        DEVICE:0 ADAPTER:13 FRONTEND:0 (Turbosight TBS 6209 (Octa DVB-T/T2/C2/C(j83-a/b/c)/)
        DEVICE:0 ADAPTER:7 FRONTEND:0 (Turbosight TBS 6209 (Octa DVB-T/T2/C2/C(j83-a/b/c)/)
        DEVICE:0 ADAPTER:3 FRONTEND:0 (Turbosight TBS 6209 (Octa DVB-T/T2/C2/C(j83-a/b/c)/)
        DEVICE:0 ADAPTER:12 FRONTEND:0 (Turbosight TBS 6209 (Octa DVB-T/T2/C2/C(j83-a/b/c)/)
        DEVICE:0 ADAPTER:6 FRONTEND:0 (Turbosight TBS 6209 (Octa DVB-T/T2/C2/C(j83-a/b/c)/)
        DEVICE:0 ADAPTER:2 FRONTEND:0 (Turbosight TBS 6209 (Octa DVB-T/T2/C2/C(j83-a/b/c)/)
        DEVICE:0 ADAPTER:15 FRONTEND:0 (Turbosight TBS 6209 (Octa DVB-T/T2/C2/C(j83-a/b/c)/)
        DEVICE:0 ADAPTER:11 FRONTEND:0 (Turbosight TBS 6209 (Octa DVB-T/T2/C2/C(j83-a/b/c)/)
        DEVICE:0 ADAPTER:9 FRONTEND:0 (Turbosight TBS 6209 (Octa DVB-T/T2/C2/C(j83-a/b/c)/)
        DEVICE:0 ADAPTER:5 FRONTEND:0 (Turbosight TBS 6209 (Octa DVB-T/T2/C2/C(j83-a/b/c)/)
        DEVICE:0 ADAPTER:1 FRONTEND:0 (Turbosight TBS 6209 (Octa DVB-T/T2/C2/C(j83-a/b/c)/)
        DEVICE:0 ADAPTER:14 FRONTEND:0 (Turbosight TBS 6209 (Octa DVB-T/T2/C2/C(j83-a/b/c)/)
        DEVICE:0 ADAPTER:10 FRONTEND:0 (Turbosight TBS 6209 (Octa DVB-T/T2/C2/C(j83-a/b/c)/)
        DEVICE:0 ADAPTER:8 FRONTEND:0 (Turbosight TBS 6209 (Octa DVB-T/T2/C2/C(j83-a/b/c)/)
These are the configuration steps I have taken:
1. Gone into the network tab of TVHeadend and created 16 networks named 6209-0 through 6209-15.
2. Disabled network discovery.
3. Gone into the "Mux" tab and assigned one frequency per network.
4. Gone into the TV Adapter tab and assigned one network to one adapter.
The Problem
The muxes all scan correctly and find the channels. However, only tuners 6209-0 and 6209-1 are successfully mapping and playing services. I have checked the configuration of the other tuners and it seems every tuner is the same but simply not working.
Any ideas?
lazerbeam84
Re: Two out of 16 Tuners Working
Postby steven » Tue May 09, 2017 3:20 pm
Please send email to our support we need to have a remote check with this
kind Regards
Postby lazerbeam84 » Tue May 09, 2017 3:28 pm
We were able to solve this ourselves. As it turns out, the EPG's also scan as a channel and we were trying to then programme the EPG's as channels. Once we realized this we were able to assign the correct frequency to the correct tuners and we were able to proceed.
lazerbeam84
Return to MOI Pro - AMD
