oldgraf wrote:Мaybe you mean 1.0.4.7 because 1.0.4.6 is broken too, see images from kostading
sorry, yes, i mean version 1.0.4.7 - i hope it will be ready soon, because lately i'm busy with a lot of things.
@didiS
your problems seem completely unrelated to this topic, because as you can read no one is having any issues with version 1.0.4.2 and basically it's the last good working version at the moment, because some bugs were introduced with the newer versions.
so, it's hard for me to understand why after you tested model 6980 and like it then went and buy the older model 6920 instead, but anyway after all you shouldn't have problems with 6920 either.
please, clarify for me - during scan SD channels are found, but the screen is black when you try to watch them or something else, because SD channels use different video codec than HD channels and if i understand you right it seems like wrong video codec setting in the software, but i'm not sure that i understand your explanation correctly.
