driver 1.0.1.9 errors
Postby someguy » Mon Sep 12, 2011 10:44 am
In TS mode lock OK
In GS mode not locked on same transponder, why?
someguy
Re: driver 1.0.1.9 errors
Postby DVB » Mon Sep 12, 2011 1:00 pm
That is not error. If transponder use Transport Stream not Generic Stream, You cannot lock it as Generic Stream, because it is not Generic Stream (if lock would be present - that would be error). One transponder cannot be TS and GS at the same time.
DVB
Postby someguy » Mon Sep 12, 2011 1:23 pm
as I known TS and GS stream(streams) encapsulates in BB-Frames when transponder uses DVB-S2. may be it righter to record transponders containes TS-streams as BB-Frames, when selected mode is GS? older version of you driver & tbsrecord work as I wrote. in new version you removed that ability.
someguy
Postby steven » Mon Sep 12, 2011 10:09 pm
Hi someguy
Next day,We will have a update about this problem. :)
and sorry about this.
Postby steven » Tue Sep 13, 2011 5:49 pm
Would you mind use this new driver to have a test.
here is the linker:
http://hotfile.com/dl/129690637/7eabf14 ... 1.rar.html
and send a test report here.
Postby someguy » Tue Sep 13, 2011 9:59 pm
thank you, Steven! i'll check your driver tommorow.
someguy
Postby someguy » Wed Sep 14, 2011 10:28 pm
new driver works better! GS and TS streams captures in original BB-frame format, as I wished. but in end of captured files(about 100 kbytes) i see some garbage(fake bytes) ...
someguy
Postby steven » Thu Sep 15, 2011 9:42 am
someguy wrote:new driver works better! GS and TS streams captures in original BB-frame format, as I wished. but in end of captured files(about 100 kbytes) i see some garbage(fake bytes) ...
Hi someguy
Would you mind have more test,and what about the older driver is it have garbage?
Postby Ebrahimi » Sat Nov 26, 2011 11:24 am
I seem to be having some issues with the OEM DVD Dream v15e OEM software (Trial version of v15f from the DVD Dream website yields the same results.) While I have no issue acquiring lock in TBS Recorder or TBS IP, whever I start DVB Dream (with the exception of once where a manual scan actually returned data), it appears there is no signal (perhaps some sort of software config issue.) I do have the correct parameters set (I'm a long time DVB user and RF engineer with experience in Satellite comms) as well as the proper LNB Local Oscillator freq, etc. At times, I have been able to start TBS recorder or TBS IP, lock to a channel, start DVB Dream, and a signal be indicated which vanishes after any of the parameters (such as transponder frequency) are set.
Ebrahimi
