QBOX S2 unable to load driver
Postby markstuartwalker » Sun Nov 21, 2010 1:11 am
I have both Ubuntu 10.10 and Windows 7 systems. The windows 7 system refuses to load the driver for the USB device.
For diagnosis I did a lsusb on my Linux server and I got
Code: Select all
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 007: ID 734c:5910 TBS Technologies China
Looking at the S2QBOX.inf files in the x86 folder there does not seem to be that code. There is ..
Code: Select all
[TBS]
"QBOX DVB-S2 BDA"= QBOXS2BDA.Device, USB\VID_734C&PID_5920
"QBOX DVB-S2 BDA"= QBOXS2BDA.Device, USB\VID_734C&PID_5928
If I manually change the 5920 to be 5910 then the driver installs .... but still does not work with Windows Media Centre - I get a blue screen
On my Ubuntu server the installation looks correct
Code: Select all
dvb-usb: found a 'TBS QBOX DVBS USB2.0' in cold state, will try to load a firmwar
dvb-usb: downloading firmware from file 'dvb-usb-tbsqbox-id5910.fw'
tbsqboxs1: start downloading TBSQBOX firmware
dvb-usb: found a 'TBS QBOX DVBS USB2.0' in warm state.
dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
DVB: registering new adapter (TBS QBOX DVBS USB2.0)
dvb-usb: MAC address: 00:c1:d2:b0:01:67
tbsqboxs1: Attached stv0288!
DVB: registering adapter 0 frontend 0 (ST STV0288 DVB-S)...
but szap2 doesn't seem to get a lock on (no green light)
Any clues?
markstuartwalker
Re: QBOX S2 unable to load driver
Postby cody » Tue Nov 23, 2010 3:08 am
your device ID "734c:5910" shows that you have Q-box DVB-S (this is the older model without DVB-S2 support). so, in Windows you have to install the following drivers:
https://shop.tbsdtv.com/download2/QBox/TB ... .0.3.0.rar
also, i believe you don't get lock in Linux, because you tried DVB-S2 signal instead of DVB-S. once again the model you own is not compatible with DVB-S2 and supports DVB-S signal only.
Postby markstuartwalker » Fri Nov 26, 2010 2:58 am
Thanks for the advice. It was so obvious that I'd missed that! The device now works perfectly under Windows Media Centre.
I still have a problem tuning in the Linux server though. I've run scan and it give me something like a reasonable channels.conf file but the Input Source in MythTV won't work.
Am I right in saying that this is now a MthTV problem?
markstuartwalker
Postby cody » Fri Nov 26, 2010 5:03 am
markstuartwalker wrote:Am I right in saying that this is now a MthTV problem?
yes, if scan works then the device and driver are installed correctly and that is some MythTV configuration problem.
Postby markstuartwalker » Fri Nov 26, 2010 8:40 pm
I'm not sure now ....
After much poking about I have run w_scan and produced a channels.conf file that MythTV seems to like but I still don't get any channels, just "Timed out, no signal" messages.
Here is a fragment of the conf file
Code: Select all
LBC News(BSkyB):11222:h:0:27500:0:2315:52031
Northern Birds(BSkyB):11222:h:0:27500:2323:2324:52050
Controversial tv(BSkyB):11222:h:0:27500:2321:2322:52056
BET +1(BSkyB):11222:h:0:27500:2327:2328:52060
Press TV(BSkyB):11222:h:0:27500:2325:2326:52070
ITV1 HD(BSkyB):10935:v:0:22000:513:641:3851
EPG Background Audio.(BSkyB):11778:v:0:27500:0:648:4152
Portal Video 5(BSkyB):11778:v:0:27500:3177:3176:8183
Sky Active Ads(BSkyB):12109:h:0:27500:519:647:5048
Sky Intro(BSkyB):11934:v:0:27500:516:644:4515
Sky Intro(BSkyB):11934:v:0:27500:516:644:4525
Sky Intro(BSkyB):11934:v:0:27500:516:644:5004
Chl Line-up(BSkyB):11934:v:0:27500:0:664:5007
Sky Intro Active(BSkyB):11934:v:0:27500:2306:2307:9321
Vegas Wanted DOA(BSkyB):12285:v:0:27500:0:2554:8023
Vegas Hit It Poker(BSkyB):12285:v:0:27500:0:3592:8069
S1Test(BSkyB):12148:h:0:27500:513:641:5308
CommunityChnl(BSkyB):11469:h:0:27500:518:646:5802
Remote Control Look Up App(BSkyB):11469:h:0:27500:0:4204:8020
Sky Preview(BSkyB):11565:v:0:27500:514:642:4505
DVD  Extras(BSkyB):11565:v:0:27500:517:645:5287
Vegas Cluedo(BSkyB):12187:h:0:27500:0:3072:8080
Vegas Monty Python(BSkyB):12187:h:0:27500:0:2542:8399
Sky News(BSkyB):12207:v:0:27500:512:640:4704
Sky News(BSkyB):12207:v:0:27500:513:641:4706
Sky News(BSkyB):12207:v:0:27500:514:642:4707
Sky News Active iText Quad(BSkyB):12207:v:0:27500:514:642:8218
Vegas Elvis(BSkyB):11507:h:0:27500:3568:3567:8035
FAQ Development(BSkyB):10861:h:0:22000:3756:3757:8015
Vegas Golden Doubloons(BSkyB):10861:h:0:22000:0:3681:8026
Vegas Diamond Compass(BSkyB):10861:h:0:22000:0:3597:8097
Portal Video 6(BSkyB):12304:h:0:27500:4162:4163:8088
1429(BSkyB):12304:h:0:27500:516:644:9345
RTE Radio 1(BSkyB):10743:h:0:22000:0:2320:9611
RTE 2FM(BSkyB):10743:h:0:22000:0:2321:9612
RTE R na G(BSkyB):10743:h:0:22000:0:2322:9613
RTE Lyric fm(BSkyB):10743:h:0:22000:0:2323:9614
Sky Games(BSkyB):10743:h:0:22000:0:2630:8107
Game Slot 20(BSkyB):10743:h:0:22000:0:2630:8115
Game Slot 18(BSkyB):10743:h:0:22000:0:2630:8118
Game Slot 22(BSkyB):10743:h:0:22000:0:2630:8128
Game Slot 26(BSkyB):10743:h:0:22000:0:2630:8140
Game Slot 17(BSkyB):10743:h:0:22000:0:2630:8146
Movies Xmas Vote(BSkyB):10743:h:0:22000:0:2542:8152
Portal Video 2(BSkyB):10743:h:0:22000:3168:3167:8199
Sky Hub Video(BSkyB):10743:h:0:22000:3165:3164:8200
BBC 1 London(BSkyB):10773:h:0:22000:5000:5001:6301
BBC 2 England(BSkyB):10773:h:0:22000:5100:5101:6302
BBC TES 3(BSkyB):10773:h:0:22000:5200:5201:6315
CBBC Channel(BSkyB):10773:h:0:22000:5200:5201:6317
FIVE(BSkyB):10773:h:0:22000:5400:5401:6335
BBC 1 West(BSkyB):10773:h:0:22000:5900:5901:6341
BBC 1 East (W)(BSkyB):10773:h:0:22000:5700:5701:6351
BBC 1 CI(BSkyB):10773:h:0:22000:5800:5801:6361
BBC R5L(BSkyB):10802:h:0:22000:0:6001:6401
ETV2(BSkyB):10802:h:0:22000:5000:5001:6407
CBeebies(BSkyB):10802:h:0:22000:5600:5601:6418
BBC 1 Scotland(BSkyB):10802:h:0:22000:5000:5001:6421
BBC 2 Scotland(BSkyB):10802:h:0:22000:5100:5101:6422
BBC 1 N West(BSkyB):10802:h:0:22000:5700:5701:6441
BBC 1 Yorks(BSkyB):10802:h:0:22000:5800:5801:6451
BBC 1 S East(BSkyB):10802:h:0:22000:5900:5901:6461
BBC R5SX(BSkyB):10802:h:0:22000:0:6101:6464
STREAM-0(BSkyB):12441:v:0:27500:5000:5001:6880
STREAM-1(BSkyB):12441:v:0:27500:5100:5101:6881
STREAM-2(BSkyB):12441:v:0:27500:5200:5201:6882
STREAM-3(BSkyB):12441:v:0:27500:5300:5301:6883
STREAM-4(BSkyB):12441:v:0:27500:5400:5401:6884
STREAM-5(BSkyB):12441:v:0:27500:5500:5501:6885
STREAM-6(BSkyB):12441:v:0:27500:5600:5601:6886
When I use this command to play the video stream in mplayer
Code: Select all
$ cp channels.conf ~/.mplayer/.
$ mplayer dvb://"Sky News(BSkyB)"
MPlayer 1.0rc4-4.4.5 (C) 2000-2010 MPlayer Team
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing dvb://Sky News(BSkyB).
dvb_tune Freq: 12207000
Not able to lock to the signal on the given frequency, timeout: 30
dvb_tune, TUNING FAILED
ERROR, COULDN'T SET CHANNEL  36: Failed to open dvb://Sky News(BSkyB).
Exiting... (End of file)
Any more suggestions?
markstuartwalker
Postby cody » Tue Nov 30, 2010 7:34 am
if you can get the channel names using 'w_scan' then it means you can receive data from the satellite, because that is how the names are generated - with analyzing the data received from the satellite.
i'm not sure if the way how you test with 'mplayer' is conclusive for anything, because i'm not sure if 'mplayer' has S2API support or if it does if your 'mplayer' version features such support. so, in any case one good and conclusive way to test with 'mplayer' is:
* lock with 'szap-s2' using "-p -r" switches (as explained in the README file that is part of the Linux driver package) and the "channels.conf" you manged to generate
* while 'szap-s2' is running and is reporting that there is lock watch the channel with 'mplayer':
mplayer /dev/dvb/adapter0/dvr0
Postby MajorTom » Thu Dec 02, 2010 12:35 am
This is the "Windows" section of the forum!
MajorTom
Postby cody » Fri Dec 03, 2010 4:03 am
MajorTom wrote:This is the "Windows" section of the forum!
:) i'm going move the thread to the Linux section.
