Tested CAMs that work with TBS 5980
Postby warumnix » Tue Sep 20, 2011 8:59 am
here a list of CAMs which TBS has tested in the lab, there are also other CAMs that work with TBS 5980, if you've found out more, just share with us
1. AlphaCrypt (Mascom)
2. Conax (NCAM HD)
3. Conax (NP4)
4. Conax (SMiT)
5. Conax (Technisat)
6. Crysto Works (Philips)
7. CYFROWY POLSAT (Nagravision)
8. DIABLO CAM Ver. 2.3
9. Easy TV (Mascom)
10. Irdeto (SMiT)
11. Irdeto Crystoworks acess (SMiT)
12. Irdeto CI+ (Skylink)
13. Irdeto HD (SMiT)
14. Viaccess (SCM)
15. Viaccess (SMiT)
16. PowerCAM Pro
Cheers
Warumnix
warumnix
Re: Tested CAMs that work with TBS 5980
Postby jamf1 » Tue Nov 15, 2011 4:12 pm
Thank you, but can you also tell us which of these are tested on linux?
thx,
Chris
jamf1
Postby bob » Sat Nov 26, 2011 1:25 pm
jamf1 wrote:Thank you, but can you also tell us which of these are tested on linux?
thx,
Chris
All of those CAMs both tested in linux and windows.
Regards!
bob
Postby o2vip » Thu Jan 19, 2012 11:12 pm
Conax (NCAM HD) off "AXN" i "news Polsat Sport" Burns with a red LED on the receiver
o2vip
Postby tunderlo » Thu Sep 05, 2013 9:59 pm
Someone know if acs secure module 3.1(neotion for example)
will work with this card?
THanks
tunderlo
Postby kafel » Sat Nov 23, 2013 7:14 am
Hi!
it's my first time: so welcome everybody!
my cam is: Aston Cam 2,6 - cyfra+ seca, and works very well with dvbviewer pro!, even with splitter smartwi theres'nt any problems. - good own list with actual transporders+ scan and every channel are OK!
kafel
Postby kafel » Thu Jan 02, 2014 5:18 am
....but there's a problem with 11411 tp on HB like in 6928:
viewtopic.php?f=55&p=30273#p30273
kafel
Postby piripino » Mon Feb 09, 2015 3:16 am
Hello, does anyone know if the Premium Cam HD Mediaset Premium Tbs work in 5980? Thank You
piripino
Postby akakiz » Thu Jun 25, 2015 4:27 pm
I have TBS6991SE and module TrophyAccess: http://trophy.com.ua/files/CAM_en.pdf
I have tried with MOI+ and PC (i686 x64), both results are similar.
Looks like this module and card is not compatible each other (driver problem).
I have tried several softwares like mumudvb, dvblas and astra, results are similar:
mumudvb replay:
Info: Main: Channel number : 0, name : "A3" service id 7702
Info: Main: Multicast4 ip : 239.255.0.3:10003
Info: Main: Channel "A3" is now highly scrambled (100% of scrambled packets). Card 1
en50221_tl_poll: CAWrite failed
en50221_stdcam_llci_poll: Error reported by stack:-2
WARN: CAM: Transport Layer Error change from EN50221ERR_NONE (No Error.) to EN50221ERR_CAWRITE (error during write to CA device.)
Info: CAM: No CAM initialization in 30s, WE FORCE A RESET. try 1 on 5.
Info: CAM: No CAM initialization in 61s, WE FORCE A RESET. try 2 on 5.
Info: CAM: No CAM initialization in 92s, WE FORCE A RESET. try 3 on 5.
astra replay:
Jun 25 11:53:20 [dvb_ca 10:0] CA: Slot 0 ready to go
Jun 25 11:53:21 [dvb_ca 10:0] CA: Slot 0 write failed [Input/output error]
Jun 25 11:53:21 [dvb_ca 10:0] CA: Slot 0 failed to send poll command. reset slot
Jun 25 11:53:23 [dvb_ca 10:0] CA: Slot 0 ready to go
Jun 25 11:53:24 [dvb_ca 10:0] CA: Slot 0 write failed [Input/output error]
Jun 25 11:53:24 [dvb_ca 10:0] CA: Slot 0 failed to send poll command. reset slot
Jun 25 11:53:26 [dvb_ca 10:0] CA: Slot 0 ready to go
Jun 25 11:53:27 [dvb_ca 10:0] CA: Slot 0 write failed [Input/output error]
Jun 25 11:53:27 [dvb_ca 10:0] CA: Slot 0 failed to send poll command. reset slot
Jun 25 11:53:30 [dvb_ca 10:0] CA: Slot 0 ready to go
Jun 25 11:53:30 [dvb_ca 10:0] CA: Slot 0 write failed [Input/output error]
Jun 25 11:53:31 [dvb_ca 10:0] CA: Slot 0 write failed [Input/output error]
Jun 25 11:53:31 [dvb_ca 10:0] CA: Slot 0 failed to send poll command. reset slot
Jun 25 11:53:33 [dvb_ca 10:0] CA: Slot 0 ready to go
Jun 25 11:53:34 [dvb_ca 10:0] CA: Slot 0 write failed [Input/output error]
Jun 25 11:53:34 [dvb_ca 10:0] CA: Slot 0 failed to send poll command. reset slot
Jun 25 11:53:37 [dvb_ca 10:0] CA: Slot 0 ready to go
Jun 25 11:53:37 [dvb_ca 10:0] CA: Slot 0 write failed [Input/output error]
Jun 25 11:53:38 [dvb_ca 10:0] CA: Slot 0 write failed [Input/output error]
Jun 25 11:53:38 [dvb_ca 10:0] CA: Slot 0 failed to send poll command. reset slot
dvblast replay:
error: en50221: cannot write to CAM device (Input/output error)
error: en50221_Init: couldn't send TPDU on slot 0
Same time this module works perfect in TV and in alternate STB.
Any solution for me?
akakiz
Postby kafel » Fri Jan 22, 2016 4:05 pm
Aston is ok with TbsCIapi 1.0.15 & 16
kafel
