Is This Right??
Is This Right??
Postby linuxdog15 » Thu Dec 09, 2010 4:08 pm
I have a USB DVB-S2 TV QBox and i have installed the drivers, I typed this(dmesg | grep QBOXS2) and i got
[ 22.241044] dvb-usb: found a 'TBS QBOXS2 DVBS2 USB2.0' in cold state, will try to load a firmware
[ 22.648028] dvb-usb: found a 'TBS QBOXS2 DVBS2 USB2.0' in warm state.
[ 22.648102] DVB: registering new adapter (TBS QBOXS2 DVBS2 USB2.0)
[ 23.320149] dvb-usb: no frontend was attached by 'TBS QBOXS2 DVBS2 USB2.0'
[ 23.320337] dvb-usb: TBS QBOXS2 DVBS2 USB2.0 successfully initialized and connected.
[ 23.344375] dvb-usb: TBS QBOXS2 DVBS2 USB2.0 successfully deinitialized and disconnected.
[ 24.682050] dvb-usb: found a 'TBS QBOXS2 DVBS2 USB2.0' in cold state, will try to load a firmware
[ 24.808022] dvb-usb: found a 'TBS QBOXS2 DVBS2 USB2.0' in warm state.
[ 24.808408] DVB: registering new adapter (TBS QBOXS2 DVBS2 USB2.0)
[ 24.996894] QBOXS2: CX24116 attached.
[ 24.998267] dvb-usb: TBS QBOXS2 DVBS2 USB2.0 successfully initialized and connected.
[ 1356.130797] dvb-usb: TBS QBOXS2 DVBS2 USB2.0 successfully deinitialized and disconnected.
Is this right??
linuxdog15
Re: Is This Right??
Postby cody » Fri Dec 24, 2010 5:52 am
hi, yes, it seems right, except:
but it is also right in case you unplugged the box 1356 seconds after you boot to Linux.
Re: Is This Right??
Postby mj1986 » Thu Feb 03, 2011 2:32 am
i have the same problem as linuxdog15 has, i think something is wrong with my qbox.
i have asus n50vc notebook running ubuntu 10.10 on it. i installed the driver and when i'm gonna check if it's true and using this command dmesg | grep QBOXS2
i got this result !!!
[ 264.124339] dvb-usb: found a 'TBS QBOXS2 DVBS2 USB2.0' in cold state, will try to load a firmware
[ 264.288374] dvb-usb: found a 'TBS QBOXS2 DVBS2 USB2.0' in warm state.
[ 264.288515] DVB: registering new adapter (TBS QBOXS2 DVBS2 USB2.0)
[ 264.368286] dvb-usb: no frontend was attached by 'TBS QBOXS2 DVBS2 USB2.0'
[ 264.368585] dvb-usb: TBS QBOXS2 DVBS2 USB2.0 successfully initialized and connected.
[ 264.385566] dvb-usb: TBS QBOXS2 DVBS2 USB2.0 successfully deinitialized and disconnected
is this really right? or i did mistake and i have to reinstall the driver. thanks in advance.
mj1986
Re: Is This Right??
Postby cody » Thu Feb 03, 2011 8:28 am
hi, please, provide the output from "dmesg | grep 24116", because for some reason:
and that indicates some error.
Re: Is This Right??
Postby mj1986 » Thu Feb 03, 2011 4:20 pm
hi again.
yeah, you're right, i got error.
[ 1820.000064] Invalid probe, probably not a CX24116 device
i heard qbox have some problems with Asus tech like motherboard and stuff and i don't know this causes the problem or not?
i was wondering if you'd mind helping me with this?
thanks.
mj1986
Re: Is This Right??
Postby cody » Fri Feb 04, 2011 5:47 am
that doesn't seem good like hardware fault in the device. please, give me the output of "lsusb" command, but i'm almost sure it's faulty box.
mj1986 wrote:i heard qbox have some problems with Asus tech like motherboard and stuff and i don't know this causes the problem or not?
that's not true, there is no such thing as problems with Asus boards - in fact probably over 50% of the motherboard in our computer in TBS are Asus.
