TBS6981 REMOTE not working in WMC7 or MediaPortal(Solved)
Postby varty » Thu Sep 29, 2011 2:09 am
I have just purchased the above card from Amazon and initially used this with ProgDVB. Everything works fine and the remote works fine when using this program. However, if I switch to Windows Media Center 7 or Team Media Portal the remote will not work at all. Infact - the only app I can get the remote working with is ProgDVB. PLEASE HELP!! - I am using the Win 7 drivers from release v2.0.0.21. I can see that the VHID drivers are installed and I am running Windows 7 x64 with SP1.
varty
Re: TBS6981 REMOTE not working in WMC7 or MediaPortal
Postby varty » Thu Sep 29, 2011 10:03 pm
I have got this working by re-installing the drivers! :)
Not sure why this wouldnt work first time though? :(
varty
Re: TBS6981 REMOTE not working in WMC7 or MediaPortal(Solved
Postby steven » Fri Sep 30, 2011 9:09 am
Nice to know the problem have solved ,i just answer your question on TBS6925 forum.
Postby Fingers » Sat Dec 31, 2011 4:36 pm
varty wrote:I have got this working by re-installing the drivers! :)
I was about to throw the remote away when I tried re-installing the same Win 7 driver file. It too worked on WMC7!
I did not believe this would work. What is going on here?!!! I have never heard of this before. Either a driver works or it doesn't! There must be some setting wrongly set on the first install and the second somehow reverses it. Odd, but thank goodness that it works.
Thank you, "Varty". Happy New Year!
Fingers
Postby Fingers » Tue Jan 03, 2012 2:58 am
It's getting better. I have managed to get it to work on DVBDream too. Don't ask me how, but it suddenly started working. Don't know what I touched but it works....
Everything is all a bit "hit and miss"?
Fingers
