my problem with the Install:
- Code: Select all
vdr01 v4l # ./tbs-x86.sh
TBS 6980/6981 driver configured for x86 platform.
vdr01 v4l # make
perl scripts/make_config_compat.pl /lib/modules/2.6.35-gentoo-r12/source ./.myconfig ./config-compat.h
creating symbolic links...
make -C firmware prep
make[1]: Entering directory `/root/tbs/linux-s2api-tbs6980_1/v4l/firmware'
make[1]: Leaving directory `/root/tbs/linux-s2api-tbs6980_1/v4l/firmware'
make -C firmware
CC ihex2fw
Generating vicam/firmware.fw
Generating dabusb/firmware.fw
Kernel build directory is /lib/modules/2.6.35-gentoo-r12/build
make -C /lib/modules/2.6.35-gentoo-r12/build SUBDIRS=/root/tbs/linux-s2api-tbs6980_1/v4l modules
make[1]: Entering directory `/usr/src/linux-2.6.35-gentoo-r12'
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/tuner-xc2028.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/tuner-simple.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/tuner-types.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/mt20xx.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/tda8290.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/tea5767.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/tea5761.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/tda9887.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/tda827x.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/au0828-core.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/au0828-i2c.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/au0828-cards.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/au0828-dvb.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/au0828-video.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/au8522_dig.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/au8522_decoder.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/flexcop-pci.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/flexcop-usb.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/flexcop.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/flexcop-fe-tuner.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/flexcop-i2c.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/flexcop-sram.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/flexcop-eeprom.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/flexcop-misc.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/flexcop-hw-filter.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/flexcop-dma.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/bttv-driver.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/bttv-cards.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/bttv-if.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/bttv-risc.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/bttv-vbi.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/bttv-i2c.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/bttv-gpio.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/bttv-input.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/bttv-audio-hook.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cpia2_v4l.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cpia2_usb.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cpia2_core.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx18-alsa-main.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx18-alsa-pcm.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx18-driver.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx18-cards.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx18-i2c.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx18-firmware.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx18-gpio.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx18-queue.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx18-streams.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx18-fileops.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx18-ioctl.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx18-controls.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx18-mailbox.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx18-vbi.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx18-audio.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx18-video.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx18-irq.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx18-av-core.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx18-av-audio.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx18-av-firmware.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx18-av-vbi.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx18-scb.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx18-dvb.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx18-io.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx231xx-audio.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx231xx-video.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx231xx-i2c.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx231xx-cards.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx231xx-core.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx231xx-avcore.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx231xx-pcb-cfg.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx231xx-vbi.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx23885-cards.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx23885-video.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx23885-vbi.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx23885-core.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx23885-i2c.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx23885-dvb.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx23885-417.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx23885-ioctl.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx23885-ir.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx23885-av.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx23885-input.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx23888-ir.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/netup-init.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cimax2.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/netup-eeprom.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx23885-f300.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx25840-core.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx25840-audio.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx25840-firmware.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx25840-vbi.o
CC [M] /root/tbs/linux-s2api-tbs6980_1/v4l/cx25840-ir.o
/root/tbs/linux-s2api-tbs6980_1/v4l/cx25840-ir.c: In function 'cx25840_ir_probe':
/root/tbs/linux-s2api-tbs6980_1/v4l/cx25840-ir.c:1239: error: implicit declaration of function 'kzalloc'
/root/tbs/linux-s2api-tbs6980_1/v4l/cx25840-ir.c:1239: warning: assignment makes pointer from integer without a cast
/root/tbs/linux-s2api-tbs6980_1/v4l/cx25840-ir.c:1254: error: implicit declaration of function 'kfree'
make[2]: *** [/root/tbs/linux-s2api-tbs6980_1/v4l/cx25840-ir.o] Error 1
make[1]: *** [_module_/root/tbs/linux-s2api-tbs6980_1/v4l] Error 2
make[1]: Leaving directory `/usr/src/linux-2.6.35-gentoo-r12'
make: *** [default] Error 2
Please Help!
Gernot
