Channels but no picture
Postby franceee » Thu Oct 13, 2011 12:14 am
Hello I,m hoping you can help, I have just purchased the TBS8922 (nice card), plugged it in to my MCE windows 7, plugged in the sat cable added to MCE and it found it straight away have got a good quality signal, scanned and found over 500 channels - only problem I am getting is when I try to view the channels, the basic BBC and ITV ETC nothing is showing on the TV - is there something I am missing IE: codec or another card needed for the sat signal any help gratefully appreciated.
When you set it up using the TSBviewer you also get good signal quality but no picture on TV
Ray
franceee
Re: Channels but no picture
Postby franceee » Sun Oct 16, 2011 3:01 am
Not really seeing a reply to my question just advertising.
franceee
Postby steven » Thu Oct 20, 2011 12:07 pm
Hi franceee
Sorry for the delay reply.Is the problem solved?
