Two problems with Ubuntu 11.10 drivers
Postby sja1440 » Sat Oct 29, 2011 1:05 am
I have encountered two blocking problems whilst using the Ubuntu 11-10 drivers (linux-tbs-drivers_111017.zip)
Can someone help me resolve them please?
Problem 1
I installed the drivers following the instructions in the README - no problems encountered. Verified that drivers were being loaded:
Code: Select all
[email protected]:~$ dmesg | grep cx23885
[   12.119727] cx23885 driver version 0.0.3 loaded
[   12.120661] cx23885 0000:02:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[   12.120866] CORE cx23885[0]: subsystem: 6921:8888, board: TurboSight TBS 6921 [card=34,autodetected]
[   12.847215] cx25840 3-0044: cx23885 A/V decoder found @ 0x88 (cx23885[0])
[   13.481936] cx25840 3-0044: loaded v4l-cx23885-avcore-01.fw firmware (16382 bytes)
[   13.489538] cx23885_dvb_register() allocating 1 frontend(s)
[   13.489543] cx23885[0]: cx23885 based dvb card
[   13.573532] DVB: registering new adapter (cx23885[0])
[   13.601101] cx23885_dev_checkrevision() Hardware revision = 0xb0
[   13.601106] cx23885[0]/0: found at 0000:02:00.0, rev: 2, irq: 17, latency: 0, mmio: 0xfe800000
[   13.601113] cx23885 0000:02:00.0: setting latency timer to 64
[   13.624145] input: cx23885 IR (TurboSight TBS 6921) as /devices/pci0000:00/0000:00:05.0/0000:02:00.0/rc/rc1/input7
[   13.627668] rc1: cx23885 IR (TurboSight TBS 6921) as /devices/pci0000:00/0000:00:05.0/0000:02:00.0/rc/rc1
[   13.627877] input: MCE IR Keyboard/Mouse (cx23885) as /devices/virtual/input/input8
[   13.628120] rc rc1: lirc_dev: driver ir-lirc-codec (cx23885) registered at minor = 1
I am unable to view any channel with tvheadend - when trying it immediately disconnects when trying - syslog shows the typical entry:
Code: Select all
Oct 27 15:54:48 PYTHAGORAS tvheadend[921]: subscription: "HTTP" subscribing on "CBS Reality+1", weight: 150, adapter: "TurboSight TBS 6921 DV$
Oct 27 15:54:48 PYTHAGORAS kernel: [  301.568589] TurboSight TBS 6921 Frontend:
Oct 27 15:54:48 PYTHAGORAS kernel: [  301.568594]  tbs6921fe - delivery system 0 is not supported
Oct 27 15:54:53 PYTHAGORAS tvheadend[921]: subscription: "HTTP" unsubscribing from "CBS Reality+1"
The syslog is scattered with very many entries " tbs6921fe - delivery system 0 is not supported".
Problem 2
I am unable to build scan-s2. I get the following error during make:
Code: Select all
[email protected]:~/TBS6921-2011-10-26/scan-s2$ make
gcc -I../linux-tbs-drivers/linux/include -c scan.c -o scan.o
In file included from scan.c:48:0:
atsc_psip_section.h:57:1: note: offset of packed bit-field ‘reserved2’ has changed in GCC 4.4
scan.c:51:2: error: #error scan-s2 requires Linux DVB driver API version 5.1!
make: *** [scan.o] Error 1
Key components of my system are:
Motherboard: ASUS M4A88TD-M EVO
CPU: athlon II X2 250E
TBS card: TBS6921
OS: ubuntu 11.10 (Linux PYTHAGORAS 3.0.0-12-generic #20-Ubuntu SMP Fri Oct 7 14:56:25 UTC 2011 x86_64 x86_64 x86_64 GNU/Linux)
sja1440
Re: Two problems with Ubuntu 11.10 drivers
Postby sja1440 » Fri Nov 04, 2011 2:49 pm
Can somebody from TBS support please tell me something?
At the moment the card is unusable.
Thank you.
sja1440
Postby SergioDanielG » Fri Nov 04, 2011 8:00 pm
Well, I'm not from TBS support, but...
Try to modify an recompile scan-s2.
open scan-s2.c
find
Code: Select all
#if DVB_API_VERSION != 5 || DVB_API_VERSION_MINOR != 1
and change to
Code: Select all
#if DVB_API_VERSION != 5 && DVB_API_VERSION_MINOR < 1
then make and make install.
Best regards.
SergioDanielG
Postby Mike40 » Thu Nov 24, 2011 5:02 pm
Has anyone managed to sort out this problem?
I am having the same errors - The syslog is scattered with very many entries " tbs6921fe - delivery system 0 is not supported".
This is the same when trying to use either Tvheadend or VDR
My system using the latest 3.x kernel 64 bit
I have downloading and installed the drivers from here which all appear to work fine.
I can scan with the scan-s2 which was included in the download whch seems to pick up all the non s2 channels ok
any ideas how to make it work with tvheadend or VDR or any other package??
thanks
Mike40
