No rule to make target TBS/linux-s2apitbs6980-1_20101024/v4l/tbs6980ctrl.o needed by TBS/linux-s2apitbs6980-1_20101024/v4l/tda18271.o
Can you help ?
jockmacmad wrote:Okay saw the other thread which says use ./v4l/tbs-x86_64.sh rather than ./tbs-x86_64.sh
# cd ./v4l
# ./tbs-x86_64.sh
# cd ..
# make && make installCC [M] /home/jock/linux-s2api-tbs6980_1/v4l/cx23885-f300.o
make[3]: *** No rule to make target `/home/jock/linux-s2api-tbs6980_1/v4l/tbs6980ctrl.o', needed by `/home/jock/linux-s2api-tbs6980_1/v4l/tda18271.o'. Stop.
make[2]: *** [_module_/home/jock/linux-s2api-tbs6980_1/v4l] Error 2
make[2]: Leaving directory `/usr/src/linux-headers-2.6.35-24-generic'
make[1]: Leaving directory `/home/jock/linux-s2api-tbs6980_1/v4l'
make: *** [all] Error 2
./v4l/tbs-x86_64.sh
cp: cannot stat `./tbs6980ctrl.o.x86_64': No such file or directory
cp: cannot stat `./tbs6980fe_driver.o.x86_64': No such file or directory
cp: cannot stat `./tbs6981ctrl.o.x86_64': No such file or directory
cp: cannot stat `./tbs6981fe_driver.o.x86_64': No such file or directory
TBS 6980/6981 driver configured for x86_64 platform.
cd ./v4l./tbs-x86_64.sh./v4l/tbs-x86_64.sh* Report this post
* Reply with quote
Re: Problem instaling drivers for TBS6981
Postby cody » Sun Dec 05, 2010 5:01 pm
hi Andrew,
those errors means that you didn't run './v4l/tbs-x86.sh' or './v4l/tbs-x86_64.sh' (depending on your platform - 32-bit or 64-bit Linux kernel) or the script doesn't finish successfully. did you get:
"TBS 6980/6981 driver configured for x86 platform."
or
"TBS 6980/6981 driver configured for x64 platform."
after executing './v4l/tbs-x86.sh' or './v4l/tbs-x86_64.sh'?
in it.or './v4l/tbs-x86_64.sh'
jockmacmad wrote:Okay so I see the mistake....
need tothen
- Code: Select all
cd ./v4l[/code]
- Code: Select all
./tbs-x86_64.sh
cody wrote:jockmacmad wrote:need tothen
- Code: Select all
cd ./v4l[/code]
- Code: Select all
./tbs-x86_64.sh
cd ./v4l./tbs-x86_64.sh ./v4l/tbs-x86_64.shjockmacmad wrote:Shh don't tell me there is a newer one I have it all working
