Problem to make the dvb-card working again
Postby chrmgg » Sat Nov 05, 2011 7:34 pm
Hello Team,
I'm having trouble to make the 6922-card work again.
I'm using yavdr 0.4.0 with all the latest updates and the kernel 2.6.38-12.
Compiling and installing the driver without a fault.
Watching TV after installing the driver just worked but on the next boot the driver won't work anymore and there is no dvb-device under /dev ?
Several tries to load and unload the driver manually failed.
What's going on there ?
I used the last drivers on your homepage v111103.
chrmgg
Re: Problem to make the dvb-card working again
Postby SergioDanielG » Sat Nov 05, 2011 7:55 pm
Did you see system logs? Can you try "tail -f /var/log/kern.log" in a terminal and load/unload driver in other terminal?
And "lspci" list your card?
Best regards.
SergioDanielG
Postby chrmgg » Sat Nov 05, 2011 10:22 pm
That's the problem.
Sometimes lspci shows the multimedia card and sometimes not ?!
chrmgg
Postby SergioDanielG » Sun Nov 06, 2011 12:35 am
It's like a pci-e slot problem or card problem. But did you try and old driver like 111017?
SergioDanielG
Postby chrmgg » Sun Nov 06, 2011 4:47 pm
SergioDanielG wrote:It's like a pci-e slot problem or card problem. But did you try and old driver like 111017?
Yes, I tried the driver before 111017. I guess it was 111013.
Are there any older drivers before ?
chrmgg
