tuning failed with linux kernel 3.1 Arch
Postby temocles0918 » Mon Nov 14, 2011 11:39 am
I have problems con my tuner TBS8920. In windows (64 bits) work perfectly, in linux con kernel 3.1 (x86_64) no!!!. I download the last driver (linux-tbs-sources_111017) and compiled perfectly.. the card is detected by linux..
Code: Select all
[[email protected] ~]$ dmesg |grep cx
[   10.237897] cx88/0: cx2388x v4l2 driver version 0.0.9 loaded
[   10.237994] cx8800 0000:06:01.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[   10.249891] cx88[0]: subsystem: 8920:8888, board: TBS 8920 DVB-S/S2 [card=72,autodetected], frontend(s): 1
[   10.249896] cx88[0]: TV tuner type 4, Radio tuner type -1
[   10.451389] cx88/2: cx2388x MPEG-TS Driver Manager version 0.0.9 loaded
[   10.776793] input: cx88 IR (TBS 8920 DVB-S/S2) as /devices/pci0000:00/0000:00:1e.0/0000:06:01.0/rc/rc0/input6
[   10.776955] rc0: cx88 IR (TBS 8920 DVB-S/S2) as /devices/pci0000:00/0000:00:1e.0/0000:06:01.0/rc/rc0
[   10.777068] input: MCE IR Keyboard/Mouse (cx88xx) as /devices/virtual/input/input7
[   10.777411] rc rc0: lirc_dev: driver ir-lirc-codec (cx88xx) registered at minor = 0
[   10.777419] cx88[0]/0: found at 0000:06:01.0, rev: 5, irq: 19, latency: 32, mmio: 0xde000000
[   10.777567] cx88[0]/0: registered device video1 [v4l2]
[   10.777635] cx88[0]/0: registered device vbi1
[   10.777663] cx88[0]/2: cx2388x 8802 Driver Manager
[   10.777677] cx88-mpeg driver manager 0000:06:01.2: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[   10.777686] cx88[0]/2: found at 0000:06:01.2, rev: 5, irq: 19, latency: 32, mmio: 0xdf000000
[   10.952926] cx88/2: cx2388x dvb driver version 0.0.9 loaded
[   10.952930] cx88/2: registering cx8802 driver, type: dvb access: shared
[   10.952935] cx88[0]/2: subsystem: 8920:8888, board: TBS 8920 DVB-S/S2 [card=72]
[   10.952938] cx88[0]/2: cx2388x based DVB/ATSC card
[   10.952940] cx8802_alloc_frontends() allocating 1 frontend(s)
[   11.146772] DVB: registering new adapter (cx88[0])
[11754.235027] cx24116_firmware_ondemand: Waiting for firmware upload (dvb-fe-cx24116.fw)...
[11754.779471] cx24116_firmware_ondemand: Waiting for firmware upload(2)...
[11759.928686] cx24116_load_firmware: FW version 1.23.86.1
[11759.928699] cx24116_firmware_ondemand: Firmware upload complete
Code: Select all
[[email protected] ~]$ uname -ra
Linux GOKU 3.1.0-4-ARCH #1 SMP PREEMPT Mon Nov 7 22:47:18 CET 2011 x86_64 Intel(R) Pentium(R) Dual CPU E2160 @ 1.80GHz GenuineIntel GNU/Linux
With kaffeine
Code: Select all
[[email protected] ~]$ kaffeine(4618) DvbDevice::frontendEvent: tuning failed
with w_scan
Code: Select all
[[email protected] w_scan]$ w_scan -fs -l UNIVERSAL -I sat_old.conf
w_scan version 20111011 (compiled for DVB API 5.3)
parsing initial tuning data "sat_old.conf"..
   transponder S  f = 12020 kHz H SR = 30000  3/4 0,35  QPSK
   transponder S  f = 12040 kHz V SR = 30000  3/4 0,35  QPSK
frontend_type DVB-S, channellist 4
output format vdr-1.6
output charset 'UTF-8', use -C <charset> to override
Info: using DVB adapter auto detection.
   /dev/dvb/adapter0/frontend0 -> DVB-S "Conexant CX24116/CX24118": very good :-))
Using DVB-S frontend (adapter /dev/dvb/adapter0/frontend0)
Using DVB API 5.3
frontend 'Conexant CX24116/CX24118' supports
INVERSION_AUTO
DVB-S
DVB-S2
FREQ (0.95GHz ... 2.15GHz)
SRATE (1.000MBd ... 45.000MBd)
using LNB "UNIVERSAL"
updating transponder list..
S  f = 12020 kHz H SR = 30000  3/4 0,35  QPSK: (time: 00:00) (time: 00:03)
S  f = 12040 kHz V SR = 30000  3/4 0,35  QPSK: (time: 00:06) (time: 00:09)
tune to: S  f = 12020 kHz H SR = 30000  3/4 0,35  QPSK  (no signal)
(time: 00:11) ----------no signal----------
(time: 00:14) ----------no signal----------
tune to: S  f = 12040 kHz V SR = 30000  3/4 0,35  QPSK  (no signal)
(time: 00:16) ----------no signal----------
(time: 00:19) ----------no signal----------
ERROR: Sorry - i couldn't get any working frequency/transponder
 Nothing to scan!!
is it drivers ?? or not.. my configuration in windows and linux it same (LNB, multiswitch, etc). Windows with dvdream perfect!!.. i need it for my new HTPC with Mythtv.. Some idea ? :(
Thanks.. in advance..... Regards.
temocles0918
Re: tuning failed with linux kernel 3.1 Arch
Postby jamf1 » Tue Nov 15, 2011 5:35 am
Maybe this thread is based on the same bug in the driver. Also no channels can be found.
jamf1
Postby temocles0918 » Tue Nov 15, 2011 10:45 am
Mmm.. maybe.. This card (8920) have problems in other kernel versions, I had a debian lenny, mmm i believed with kernel 2.6.35rc, but with news drivers (thanks cody), work, until that i lost my HDD and my information with my pc, these past few months :( ..
i bought others components for other computer (type HTPC) and i installed a new linux distribution with your ultimate kernel (3.1), compile perfectly, but not work. :cry: the same.. :( :(
The card is excellent, but my firt systems is in linux.. not like windows..
temocles0918
Postby temocles0918 » Thu Nov 17, 2011 11:14 am
Mmm.. new driver V111115. i compiled..
The same, not signal :( :( :(
Code: Select all
   transponder S  f = 12020 kHz V SR = 30000  3/4 0,35  QPSK
   transponder S  f = 12040 kHz H SR = 30000  3/4 0,35  QPSK
Using DVB API 5.3
INVERSION_AUTO
DVB-S
DVB-S2
S  f = 12020 kHz V SR = 30000  3/4 0,35  QPSK: (time: 00:00) (time: 00:03)
S  f = 12040 kHz H SR = 30000  3/4 0,35  QPSK: (time: 00:06) (time: 00:09)
tune to: S  f = 12020 kHz V SR = 30000  3/4 0,35  QPSK  (no signal)
(time: 00:12) ----------no signal----------
tune to: S  f = 12040 kHz H SR = 30000  3/4 0,35  QPSK  (no signal)
 Nothing to scan!!
temocles0918
Postby temocles0918 » Tue Nov 22, 2011 9:33 am
I'm sad :cry: :cry: . i download new driver 111118.. i compiled and nothing... not work.. tunning failed !!!!... and i hope bought other card (TBS6981) for other pc.... muaaaa.... :cry: and i know that drivers not function...
temocles0918
Postby SergioDanielG » Tue Nov 22, 2011 7:28 pm
temocles0918 wrote:Hi
Hi temocles0918.
Can you say me witch satellite are you trying to lock? And can you post the content of your sat_old.conf ?
Remember, TBS8920 haven't got blindscan hardware and need all real parameters to lock.
Best regards.
SergioDanielG
Postby temocles0918 » Fri Nov 25, 2011 10:54 am
Hi temocles0918.
Best regards.
Hi.. thanks
My file sat_old.conf
S 12020000 V 30000000 3/4
S 12040000 H 30000000 3/4
I am make test with Intelsat 9.
in kaffeine, the card have signal (power), however not unlocked.. :( . In windows 7, work card perfectly with dvbdream.. my subscripter receiver have signal
temocles0918
Postby richh » Wed Dec 21, 2011 9:39 pm
I guess your problem is unrelated to drier, but v4l-dvb support for 64bit kernels. There is issue that not all IOCTL have alreaday made translations from 32bit to 64bit. Check your dmesg after try to tune with kaffeine if you see there messages related to ioctl32 errors.
Currently it will affect some set of popular appliactions use frontend ioctls calls, I have to note kaffeine, dvblast, couple from dvb-apps...
Simply if you are using some 32bit appliactions which are doing some FE ioctls calls thay will not work because in dvb kernel are not made till yet some part of new code. You have to compile kernel into 32bit to be iocatl calls supported as they exist currently.
At least it works for me such.
richh
