6 Pin power connector
Postby subvertbeats » Tue Feb 01, 2011 3:34 am
Hello
I have 2 TBS 6981 cards in my HTPC.
Each card has a 6 pin power connector on the board.
Each card was supplied with a 6 pin to 3 x Molex cable.
Can you please confirm if I need to
a) Connect these cables at all?
b) If yes, then do I need to connect each of the 3 Molex's per card (I dont have enough Molex's from the PSU to do this)
Thank you.
subvertbeats
Re: 6 Pin power connector
Postby BluetoothBG » Tue Feb 01, 2011 6:30 am
You can see this topic: https://shop.tbsdtv.com/forum/viewtopic.php?f=21&t=144
Sofia, Bulgaria
TBS 6981 DVB-S/S2 | Triax TD88 | Inverto 0.2dB TWIN @ { 39E, 45E }
TBS 6921 DVB-S/S2 | Triax TD78 | Inverto 0.2dB TWIN @ { 0.8W }
BluetoothBG
Postby subvertbeats » Tue Feb 01, 2011 8:07 am
Thank you!
subvertbeats
