Ubuntu 11.04 - 2.6.38.12 tbs 6981 driver install
Postby tricky720101 » Sun Nov 27, 2011 9:15 am
I have just installed a second tbs dvb-s2 card and cannot get ubuntu to recognize the card. I have a tbs 8920 already running on the system with no issues.
I have tried to install the latest drivers from this site contained in the linux-tbs-drivers_111118.zip file but this does not contain the tbs6981ctrl.o.x86 object file needed to create the driver. This is the error
make[3]: *** No rule to make target `/home/rwalsh/Downloads/tbstemp/linux-tbs-drivers_111118/linux-tbs-drivers/v4l/tbs8921ctrl.o', needed by `/home/rwalsh/Downloads/tbstemp/linux-tbs-drivers_111118/linux-tbs-drivers/v4l/media.o'. Stop.
I am assuming the the ./tbs-x86.sh script makes the symbolic link to tbs6981ctrl.o.x86 as I have seen this step described in previous posts trying to help users setup this card.
I have downloaded the files http://www.tbsdtv.com/download/TBS6981/ ... 101024.rar which does contain the tbs6981ctrl.o.x86 object file and followed the guide http://blog.mohammadzadeh.info/index.ph ... e-tbs-6980 but this also failed to enable ubuntu to recognize the card.
This is the dmesg|grep cx showing the 8920 but no 6981
[ 21.003930] cx88/2: cx2388x MPEG-TS Driver Manager version 0.0.8 loaded
[ 21.005584] cx88[0]: subsystem: 8920:8888, board: TBS 8920 DVB-S/S2 [card=72,autodetected], frontend(s): 1
[ 21.005587] cx88[0]: TV tuner type 4, Radio tuner type -1
[ 21.008750] cx88/0: cx2388x v4l2 driver version 0.0.8 loaded
[ 21.572251] input: cx88 IR (TBS 8920 DVB-S/S2) as /devices/pci0000:00/0000:00:1e.0/0000:05:01.2/rc/rc0/input5
[ 21.572954] rc0: cx88 IR (TBS 8920 DVB-S/S2) as /devices/pci0000:00/0000:00:1e.0/0000:05:01.2/rc/rc0
[ 21.572958] cx88[0]/2: cx2388x 8802 Driver Manager
[ 21.572970] cx88-mpeg driver manager 0000:05:01.2: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 21.572976] cx88-mpeg driver manager 0000:05:01.2: setting latency timer to 64
[ 21.572982] cx88[0]/2: found at 0000:05:01.2, rev: 5, irq: 17, latency: 64, mmio: 0xf8000000
[ 21.573093] cx8800 0000:05:01.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 21.573100] cx88[0]/0: found at 0000:05:01.0, rev: 5, irq: 17, latency: 20, mmio: 0xf7000000
[ 21.580454] cx88[0]/0: registered device video0 [v4l2]
[ 21.580511] cx88[0]/0: registered device vbi0
[ 21.606433] cx88/2: cx2388x dvb driver version 0.0.8 loaded
[ 21.606437] cx88/2: registering cx8802 driver, type: dvb access: shared
[ 21.606440] cx88[0]/2: subsystem: 8920:8888, board: TBS 8920 DVB-S/S2 [card=72]
[ 21.606442] cx88[0]/2: cx2388x based DVB/ATSC card
[ 21.606444] cx8802_alloc_frontends() allocating 1 frontend(s)
[ 21.650289] DVB: registering new adapter (cx88[0])
hope you can help
I have tried to add an attachment of my lspci log but was not allowed so here if=s the text......
00:00.0 Host bridge [0600]: Intel Corporation 82975X Memory Controller Hub [8086:277c] (rev c0)
Subsystem: Micro-Star International Co., Ltd. Device [1462:7246]
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-
Latency: 0
Capabilities: [e0] Vendor Specific Information: Len=09 <?>
Kernel modules: i82975x_edac
00:01.0 PCI bridge [0604]: Intel Corporation 82975X PCI Express Root Port [8086:277d] (rev c0) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000b000-0000bfff
Memory behind bridge: fa000000-fcffffff
Prefetchable memory behind bridge: 00000000d0000000-00000000dfffffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
BridgeCtl: Parity- SERR- NoISA- VGA+ MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [88] Subsystem: Intel Corporation Device [8086:0000]
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
Address: fee0300c Data: 4151
Capabilities: [a0] Express (v1) Root Port (Slot+), MSI 00
ExtTag- RBE- FLReset-
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
LnkCap: Port #2, Speed 2.5GT/s, Width x16, ASPM L0s, Latency L0 <256ns, L1 <4us
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- Retrain- CommClk+
LnkSta: Speed 2.5GT/s, Width x16, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
Slot #0, PowerLimit 0.000W; Interlock- NoCompl-
SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
Control: AttnInd Off, PwrInd On, Power- Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
Changed: MRL- PresDet+ LinkState-
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna- CRSVisible-
RootCap: CRSVisible-
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
Capabilities: [100 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed+ WRR32- WRR64- WRR128-
Ctrl: ArbSelect=Fixed
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=01
Status: NegoPending- InProgress-
Capabilities: [140 v1] Root Complex Link
Desc: PortNumber=02 ComponentID=01 EltType=Config
Link0: Desc: TargetPort=00 TargetComponent=01 AssocRCRB- LinkType=MemMapped LinkValid+
Addr: 00000000fed19000
Link1: Desc: TargetPort=03 TargetComponent=01 AssocRCRB- LinkType=Config LinkValid+
Addr: 00:03.0 CfgSpace=0000000000018000
Kernel driver in use: pcieport
Kernel modules: shpchp
00:1b.0 Audio device [0403]: Intel Corporation N10/ICH 7 Family High Definition Audio Controller [8086:27d8] (rev 01)
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Interrupt: pin A routed to IRQ 45
Region 0: Memory at fdff8000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [50] Power Management version 2
Flags: PMEClk- DSI- D1- D2- AuxCurrent=55mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fee0300c Data: 4199
Capabilities: [70] Express (v1) Root Complex Integrated Endpoint, MSI 00
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
LnkCap: Port #0, Speed unknown, Width x0, ASPM unknown, Latency L0 <64ns, L1 <1us
LnkCtl: ASPM Disabled; Disabled- Retrain- CommClk-
LnkSta: Speed unknown, Width x0, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
Status: InProgress-
VC1: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Ctrl: Enable+ ID=1 ArbSelect=Fixed TC/VC=80
Capabilities: [130 v1] Root Complex Link
Desc: PortNumber=0f ComponentID=02 EltType=Config
Link0: Desc: TargetPort=00 TargetComponent=02 AssocRCRB- LinkType=MemMapped LinkValid+
Addr: 00000000fed1c000
Kernel driver in use: HDA Intel
Kernel modules: snd-hda-intel
00:1c.0 PCI bridge [0604]: Intel Corporation N10/ICH 7 Family PCI Express Port 1 [8086:27d0] (rev 01) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 0000a000-0000afff
Memory behind bridge: fd900000-fd9fffff
Prefetchable memory behind bridge: 00000000fd700000-00000000fd7fffff
BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
Capabilities: [40] Express (v1) Root Port (Slot+), MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
DevCtl: Report errors: Correctable- Non-Fatal- Fatal+ Unsupported-
LnkCap: Port #1, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 <1us, L1 <4us
ClockPM- Surprise- LLActRep+ BwNot-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled+ Retrain- CommClk-
LnkSta: Speed 2.5GT/s, Width x0, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+
Slot #16, PowerLimit 10.000W; Interlock- NoCompl-
Control: AttnInd Unknown, PwrInd Unknown, Power- Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet- Interlock-
Changed: MRL- PresDet- LinkState-
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal+ PMEIntEna- CRSVisible-
Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
Address: fee0300c Data: 4159
Capabilities: [90] Subsystem: Intel Corporation N10/ICH 7 Family PCI Express Port 1 [8086:27d0]
Capabilities: [a0] Power Management version 2
Status: InProgress-
Arb: Fixed+ WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable- ID=0 ArbSelect=Fixed TC/VC=00
Capabilities: [180 v1] Root Complex Link
Desc: PortNumber=01 ComponentID=02 EltType=Config
Addr: 00000000fed1c001
00:1c.1 PCI bridge [0604]: Intel Corporation N10/ICH 7 Family PCI Express Port 2 [8086:27d2] (rev 01) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: fde00000-fdefffff
Prefetchable memory behind bridge: 00000000fdd00000-00000000fddfffff
LnkCap: Port #2, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 <256ns, L1 <4us
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt-
Slot #17, PowerLimit 10.000W; Interlock- NoCompl-
Changed: MRL- PresDet+ LinkState+
Address: fee0300c Data: 4161
Capabilities: [90] Subsystem: Intel Corporation N10/ICH 7 Family PCI Express Port 2 [8086:27d2]
Status: InProgress-
Desc: PortNumber=02 ComponentID=02 EltType=Config
00:1c.5 PCI bridge [0604]: Intel Corporation 82801GR/GH/GHM (ICH7 Family) PCI Express Port 6 [8086:27e2] (rev 01) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: fdb00000-fdcfffff
Prefetchable memory behind bridge: 00000000fda00000-00000000fdafffff
LnkCap: Port #6, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 <256ns, L1 <4us
Slot #21, PowerLimit 10.000W; Interlock- NoCompl-
Address: fee0300c Data: 4169
Capabilities: [90] Subsystem: Intel Corporation 82801GR/GH/GHM (ICH7 Family) PCI Express Port 6 [8086:27e2]
Status: InProgress-
Desc: PortNumber=06 ComponentID=02 EltType=Config
00:1d.0 USB Controller [0c03]: Intel Corporation N10/ICH 7 Family USB UHCI Controller #1 [8086:27c8] (rev 01) (prog-if 00 [UHCI])
Control: I/O+ Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 23
Region 4: I/O ports at ff00 [size=32]
Kernel driver in use: uhci_hcd
00:1d.1 USB Controller [0c03]: Intel Corporation N10/ICH 7 Family USB UHCI Controller #2 [8086:27c9] (rev 01) (prog-if 00 [UHCI])
Latency: 0
Interrupt: pin B routed to IRQ 19
Region 4: I/O ports at fe00 [size=32]
00:1d.2 USB Controller [0c03]: Intel Corporation N10/ICH 7 Family USB UHCI Controller #3 [8086:27ca] (rev 01) (prog-if 00 [UHCI])
Latency: 0
Interrupt: pin C routed to IRQ 18
Region 4: I/O ports at fd00 [size=32]
00:1d.3 USB Controller [0c03]: Intel Corporation N10/ICH 7 Family USB UHCI Controller #4 [8086:27cb] (rev 01) (prog-if 00 [UHCI])
Latency: 0
Interrupt: pin D routed to IRQ 16
Region 4: I/O ports at fc00 [size=32]
00:1d.7 USB Controller [0c03]: Intel Corporation N10/ICH 7 Family USB2 EHCI Controller [8086:27cc] (rev 01) (prog-if 20 [EHCI])
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Region 0: Memory at fdfff000 (32-bit, non-prefetchable) [size=1K]
Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Kernel driver in use: ehci_hcd
00:1e.0 PCI bridge [0604]: Intel Corporation 82801 PCI Bridge [8086:244e] (rev e1) (prog-if 01 [Subtractive decode])
Latency: 0
Bus: primary=00, secondary=05, subordinate=05, sec-latency=32
I/O behind bridge: 0000c000-0000cfff
Memory behind bridge: f7000000-f9ffffff
Prefetchable memory behind bridge: 00000000fd800000-00000000fd8fffff
Secondary status: 66MHz- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR+
Capabilities: [50] Subsystem: Intel Corporation 82801 PCI Bridge [8086:244e]
00:1f.0 ISA bridge [0601]: Intel Corporation 82801GH (ICH7DH) LPC Interface Bridge [8086:27b0] (rev 01)
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Capabilities: [e0] Vendor Specific Information: Len=0c <?>
Kernel modules: leds-ss4200, iTCO_wdt
00:1f.1 IDE interface [0101]: Intel Corporation 82801G (ICH7 Family) IDE Controller [8086:27df] (rev 01) (prog-if 8a [Master SecP PriP])
Latency: 0
Interrupt: pin A routed to IRQ 18
Region 0: I/O ports at 01f0 [size=8]
Region 1: I/O ports at 03f4 [size=1]
Region 2: I/O ports at 0170 [size=8]
Region 3: I/O ports at 0374 [size=1]
Region 4: I/O ports at fb00 [size=16]
Kernel driver in use: ata_piix
00:1f.2 IDE interface [0101]: Intel Corporation N10/ICH7 Family SATA IDE Controller [8086:27c0] (rev 01) (prog-if 8f [Master SecP SecO PriP PriO])
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Region 0: I/O ports at fa00 [size=8]
Region 1: I/O ports at f900 [size=4]
Region 2: I/O ports at f800 [size=8]
Region 3: I/O ports at f700 [size=4]
Region 4: I/O ports at f600 [size=16]
Region 5: Memory at fdffe000 (32-bit, non-prefetchable) [size=1K]
Capabilities: [70] Power Management version 2
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot+,D3cold-)
00:1f.3 SMBus [0c05]: Intel Corporation N10/ICH 7 Family SMBus Controller [8086:27da] (rev 01)
Control: I/O+ Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Interrupt: pin B routed to IRQ 15
Region 4: I/O ports at 0500 [size=32]
Kernel modules: i2c-i801
01:00.0 VGA compatible controller [0300]: nVidia Corporation G71 [GeForce 7300 GS] [10de:01df] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Giga-byte Technology Device [1458:3413]
Region 0: Memory at fa000000 (32-bit, non-prefetchable) [size=16M]
Region 1: Memory at d0000000 (64-bit, prefetchable) [size=256M]
Region 3: Memory at fb000000 (64-bit, non-prefetchable) [size=16M]
[virtual] Expansion ROM at fc000000 [disabled] [size=128K]
Capabilities: [60] Power Management version 2
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [78] Express (v1) Endpoint, MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <256ns, L1 <4us
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
LnkCap: Port #0, Speed 2.5GT/s, Width x16, ASPM L0s L1, Latency L0 <256ns, L1 <4us
LnkCtl: ASPM Disabled; RCB 128 bytes Disabled- Retrain- CommClk+
Status: InProgress-
Capabilities: [128 v1] Power Budgeting <?>
Kernel driver in use: nouveau
Kernel modules: nouveau, nvidiafb
03:00.0 SATA controller [0106]: JMicron Technology Corp. JMB361 AHCI/IDE [197b:2361] (rev 02) (prog-if 01 [AHCI 1.0])
Interrupt: pin A routed to IRQ 17
Region 5: Memory at fdefe000 (32-bit, non-prefetchable) [size=8K]
Capabilities: [68] Power Management version 2
Capabilities: [50] Express (v1) Legacy Endpoint, MSI 01
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq+ AuxPwr- TransPend-
LnkCap: Port #1, Speed 2.5GT/s, Width x1, ASPM L0s, Latency L0 <1us, L1 <16us
Kernel driver in use: ahci
Kernel modules: ahci
03:00.1 IDE interface [0101]: JMicron Technology Corp. JMB361 AHCI/IDE [197b:2361] (rev 02) (prog-if 85 [Master SecO PriO])
Latency: 0
Interrupt: pin B routed to IRQ 18
Region 0: I/O ports at ef00 [size=8]
Region 1: I/O ports at ee00 [size=4]
Region 2: I/O ports at ed00 [size=8]
Region 3: I/O ports at ec00 [size=4]
Region 4: I/O ports at eb00 [size=16]
Kernel driver in use: pata_jmicron
Kernel modules: pata_jmicron
04:00.0 Ethernet controller [0200]: Intel Corporation 82573L Gigabit Ethernet Controller [8086:109a]
Subsystem: Micro-Star International Co., Ltd. Device [1462:246c]
Interrupt: pin A routed to IRQ 44
Region 0: Memory at fdce0000 (32-bit, non-prefetchable) [size=128K]
Region 1: Memory at fdb00000 (32-bit, non-prefetchable) [size=1M]
Region 2: I/O ports at df00 [size=32]
Capabilities: [c8] Power Management version 2
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=1 PME-
Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fee0100c Data: 4191
Capabilities: [e0] Express (v1) Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM unknown, Latency L0 <128ns, L1 <64us
ClockPM+ Surprise- LLActRep- BwNot-
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
AERCap: First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
Capabilities: [140 v1] Device Serial Number 00-19-db-ff-ff-62-62-a8
Kernel driver in use: e1000e
Kernel modules: e1000e
05:00.0 Multimedia video controller [0400]: Brooktree Corporation Bt878 Video Capture [109e:036e] (rev 02)
Latency: 16 (4000ns min, 10000ns max)
Region 0: Memory at fd8ff000 (32-bit, prefetchable) [size=4K]
Kernel driver in use: bttv
Kernel modules: bttv
05:00.1 Multimedia controller [0480]: Brooktree Corporation Bt878 Audio Capture [109e:0878] (rev 02)
Latency: 4 (1000ns min, 63750ns max)
Interrupt: pin A routed to IRQ 10
Region 0: Memory at fd8fe000 (32-bit, prefetchable) [size=4K]
05:01.0 Multimedia video controller [0400]: Conexant Systems, Inc. CX23880/1/2/3 PCI Video and Audio Decoder [14f1:8800] (rev 05)
Subsystem: Device [8920:8888]
Latency: 20 (5000ns min, 13750ns max), Cache Line Size: 64 bytes
Region 0: Memory at f7000000 (32-bit, non-prefetchable) [size=16M]
Capabilities: [44] Vital Product Data
No end tag found
Capabilities: [4c] Power Management version 2
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Kernel driver in use: cx8800
Kernel modules: cx8800
05:01.2 Multimedia controller [0480]: Conexant Systems, Inc. CX23880/1/2/3 PCI Video and Audio Decoder [MPEG Port] [14f1:8802] (rev 05)
Latency: 64 (1500ns min, 22000ns max), Cache Line Size: 64 bytes
Region 0: Memory at f8000000 (32-bit, non-prefetchable) [size=16M]
Kernel driver in use: cx88-mpeg driver manager
Kernel modules: cx8802
05:03.0 FireWire (IEEE 1394) [0c00]: VIA Technologies, Inc. VT6306/7/8 [Fire II(M)] IEEE 1394 OHCI Controller [1106:3044] (rev c0) (prog-if 10 [OHCI])
Subsystem: Micro-Star International Co., Ltd. Device [1462:246d]
Latency: 64 (8000ns max), Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 19
Region 0: Memory at f9fff000 (32-bit, non-prefetchable) [size=2K]
Region 1: I/O ports at cf00 [size=128]
Flags: PMEClk- DSI- D1- D2+ AuxCurrent=0mA PME(D0-,D1-,D2+,D3hot+,D3cold+)
Kernel driver in use: firewire_ohci
Kernel modules: firewire-ohci
cheers
Rick
tricky720101
Re: Ubuntu 11.04 - 2.6.38.12 tbs 6981 driver install
Postby cody » Mon Nov 28, 2011 7:13 pm
hi Rick,
you simply don't follow the installation instructions described step-by-step at the beginning of any of the README files (for example README_TBS6981) included in the Linux driver package. so, you don't need to do anything special or difficult just follow the installation instructions. that's why we put guide how to report problems in Linux:
viewtopic.php?f=22&t=2197
and emphasize to make sure to read and follow what README files instructs for making proper installation before report a problem. basically, your problem is not really a problem and there is nothing wrong with latest version "111118" drivers - you just missed to read and follow the installation instructions and let me put them here once again:
I.1 extract linux-tbs-drivers.tar.bz2 archive:
# tar xjvf linux-tbs-drivers.tar.bz2
I.2 go to driver package directory:
# cd linux-tbs-drivers
I.3 depending on your kernel version and if the kernel is x86 or
x86_64 (check output of 'uname -a') do:
- for x86 kernel 3.x (x86 32 bit installations of kernel 3.x):
# ./v4l/tbs-x86_r3.sh
- for x86 kernel 2.6.x (x86 32 bit installations of kernel 2.6.x):
# ./v4l/tbs-x86.sh
- for any x86_64 kernel (x86 64 bit installations of Linux):
# ./v4l/tbs-x86_64.sh
I.3 build and install the driver:
# make && make install
I.4 reboot in order to load the newly installed driver:
# shutdown -r now
Postby davidea » Sun Dec 11, 2011 2:27 am
thanks cody for the helpfull hint
please if possible to add this hint in the file onto the directory
/READMEs/
i've a qboxs2 , and i read only the file for qboxs2 & ubuntu, i've ignored the file TBS5921 (but i've used the power of google!!!)
bye
davidea
Users browsing this forum: No registered users and 16 guests
