szap-s2 works, scan-s2 does not [SOLVED]
Postby Euge » Wed Feb 09, 2011 7:57 am
I've successfully installed the drivers (Gentoo 2.6.35-r15).
After reading some of the other posts on this forum I've successfully got szap-s2 tuning:
Code: Select all
mediacentre szap-s2 # ./szap-s2 -a 2 -H -c ../bbc1london.conf -S 0 "BBC 1 London;BSkyB"
reading channels from file '../bbc1london.conf'
zapping to 1 'BBC 1 London;BSkyB':
sat 0, frequency 10773 MHz H, symbolrate 22000000, coderate 5/6, rolloff 0.35
vpid 0x1388, apid 0x1389, sid 0x138b
using '/dev/dvb/adapter2/frontend0' and '/dev/dvb/adapter2/demux0'
status 1f | signal  74% | snr  87% | ber 0 | unc 0 | FE_HAS_LOCK
status 1f | signal  74% | snr  97% | ber 0 | unc 0 | FE_HAS_LOCK
status 1f | signal  74% | snr  98% | ber 0 | unc 0 | FE_HAS_LOCK
bb1london.conf contains:
Code: Select all
BBC 1 London;BSkyB:10773:hC56M2O35S0:S28.2E:22000:5000:5001=eng,5002=NAR:5003:0:6301:2:2045:0
However, I'm struggling to get scan-s2 to scan for channels:
Code: Select all
mediacentre scan-s2 # ./scan-s2 -a 2 ../astra_scan-s2.conf
API major 5, minor 1
scanning ../astra_scan-s2.conf
initial transponder DVB-S  10773000 H 22000000 5/6 35 QPSK
initial transponder DVB-S  11778000 V 27500000 3/4 35 QPSK
initial transponder DVB-S2 11362000 H 22000000 2/3 35 8PSK
>>> tune to: 10773:hC56M2O35S0:S0.0W:22000:
DVB-S IF freq is 1023000
WARNING: filter timeout pid 0x0010
>>> tune to: 11778:vC34M2O35S0:S0.0W:27500:
DVB-S IF freq is 1178000
WARNING: >>> tuning failed!!!
>>> tune to: 11778:vC34M2O35S0:S0.0W:27500: (tuning failed)
----------------------------------> Using DVB-S2
>>> tune to: 11362:hC23M5O35S1:S0.0W:22000:
DVB-S IF freq is 1612000
>>> tune to: 11362:hC23M5O35S1:S0.0W:22000: (tuning failed)
dumping lists (0 services)
Done.
astra_scan-s2.conf contains:
Code: Select all
S1 10773000 H 22000000 5/6 35 QPSK
S1 11778000 V 27500000 3/4 35 QPSK
Can anyone point me in the correct direction? I believe the fact that szap is getting a lock implies the card is successfully tuning.
Look forward to hearing from anyone who can help!
Regards,
Euge
Euge
Re: szap-s2 works, scan-s2 does not
Postby Derrick » Wed Feb 09, 2011 6:50 pm
Apparently you are trying to scan transponders from 19E.
10773H has been switched off ;) Did you check your diseqc settings?
Derrick
Postby Euge » Wed Feb 09, 2011 9:38 pm
Hi, thanks for the response.
Do you mean the -r switch for scan-s2? e.g. ./scan-s2 ... -r 28.2E
On my system there's a list of settings for Astra 28.2E in /usr/share/dvb/dvb-s/Astra-28.2E:
Code: Select all
# Astra 28.2E SDT info service transponder
# freq pol sr fec
## Astra 2A
# Transponder 1
S 11720000 H 29500000 3/4
# Transponder 2
S 11740000 V 27500000 2/3
# Transponder 3
S 11758000 H 27500000 2/3
# Transponder 4
S 11778000 V 27500000 2/3
# Transponder 5
S 11798000 H 29500000 3/4
# Transponder 6
S 11817000 V 27500000 2/3
# Transponder 7
S 11836000 H 27500000 2/3
# Transponder 8
S 11856000 V 27500000 2/3
# Transponder 9
S 11876000 H 27500000 2/3
# Transponder 10
S 11895000 V 27500000 2/3
# Transponder 11
S 11914000 H 27500000 2/3
# Transponder 12
S 11934000 V 27500000 2/3
# Transponder 13
S 11954000 H 27500000 2/3
# Transponder 18
S 12051000 V 27500000 2/3
# Transponder 22
S 12129000 V 27500000 2/3
# Transponder 23
S 12148000 H 27500000 2/3
# Transponder 24
S 12168000 V 27500000 2/3
# Transponder 27
S 12226000 H 27500000 2/3
# Transponder 28
S 12246000 V 27500000 2/3
# Transponder 37
S 12422000 H 27500000 2/3
# Transponder 40
S 12480000 V 27500000 2/3
## Astra 2B
# Transponder 14
S 11973000 V 27500000 2/3
# Transponder 15
S 11992000 H 27500000 2/3
# Transponder 16
S 12012000 V 27500000 2/3
# Transponder 17
S 12032000 H 27500000 2/3
# Transponder 19
S 12070000 H 27500000 2/3
# Transponder 20
S 12090000 V 27500000 2/3
# Transponder 21
S 12110000 H 27500000 2/3
# Transponder 25
S 12188000 H 27500000 2/3
# Transponder 26
S 12207000 V 27500000 2/3
# Transponder 29
S 12266000 H 27500000 2/3
# Transponder 30
S 12285000 V 27500000 2/3
# Transponder 31
S 12304000 H 27500000 2/3
# Transponder 32
S 12324000 V 29500000 3/4
# Transponder 33
S 12344000 H 29500000 3/4
# Transponder 34
S 12363000 V 29500000 3/4
# Transponder 35
S 12382000 H 27500000 2/3
# Transponder 36
S 12402000 V 27500000 2/3
# Transponder 38
S 12441000 V 27500000 2/3
# Transponder 39
S 12460000 H 27500000 2/3
## Astra 2D
# Transponder 41
S 10714000 H 22000000 5/6
# Transponder 42
S 10729000 V 22000000 5/6
# Transponder 43
S 10744000 H 22000000 5/6
# Transponder 44
S 10758000 V 22000000 5/6
# Transponder 45
# Transponder 46
S 10788000 V 22000000 5/6
# Transponder 47
S 10803000 H 22000000 5/6
# Transponder 48
S 10818000 V 22000000 5/6
# Transponder 49
S 10832000 H 22000000 5/6
# Transponder 50
S 10847000 V 22000000 5/6
# Transponder 51
S 10862000 H 22000000 5/6
# Transponder 52
S 10876000 V 22000000 5/6
# Transponder 53
S 10891000 H 22000000 5/6
# Transponder 54
S 10906000 V 22000000 5/6
# Transponder 55
S 10921000 H 22000000 5/6
# Transponder 56
S 10936000 V 22000000 5/6
## Eurobird 1
# Transponder C1
S 11222170 H 27500000 2/3
# Transponder C2
S 11223670 V 27500000 2/3
# Transponder C2
S 11259000 V 27500000 2/3
# Transponder C1
S 11261000 H 27500000 2/3
# Transponder C3
S 11307000 H 27500000 2/3
# Transponder C4
S 11307000 V 27500000 2/3
# Transponder C4
S 11343000 V 27500000 2/3
# Transponder C3
S 11344000 H 27500000 2/3
# Transponder C5
S 11390000 H 27500000 2/3
# Transponder C6
S 11390000 V 27500000 2/3
# Transponder C5
S 11426000 H 27500000 2/3
# Transponder C6
S 11426000 V 27500000 2/3
# Transponder D1
S 11469000 H 27500000 2/3
# Transponder D2S
S 11488000 V 27500000 2/3
# Transponder D3S
S 11508000 H 27500000 2/3
# Transponder D4S
S 11527000 V 27500000 2/3
# Transponder D5
S 11546000 H 27500000 2/3
# Transponder D6
S 11565000 V 27500000 2/3
# Transponder D7
S 11585000 H 27500000 2/3
# Transponder D8
S 11603850 V 27500000 2/3
# Transponder D9
S 11623000 H 27500000 2/3
# Transponder D10
S 11642000 V 27500000 2/3
# Transponder D11
S 11661540 H 27500000 2/3
# Transponder D12
S 11680770 V 27500000 2/3
# Transponder F1
S 12524000 H 27500000 2/3
# Transponder F2
S 12524000 V 27500000 2/3
# Transponder F1
S 12560000 H 27500000 2/3
# Transponder F2
S 12560000 V 27500000 2/3
# Transponder F4
S 12596000 V 27500000 2/3
# Transponder F3
S 12607000 H 27500000 3/4
# Transponder F4
S 12629000 V 6111000 3/4
# Transponder F5
S 12692000 V 19532000 1/2
I've tried this with the -r 28.2E setting and still no joy:
Code: Select all
mediacentre scan-s2 # ./scan-s2 -a 2 /usr/share/dvb/dvb-s/Astra-28.2E -r 28.2E
scanning /usr/share/dvb/dvb-s/Astra-28.2E
initial transponder DVB-S  11720000 H 29500000 3/4 AUTO AUTO
initial transponder DVB-S2 11720000 H 29500000 3/4 AUTO AUTO
initial transponder DVB-S  11740000 V 27500000 2/3 AUTO AUTO
initial transponder DVB-S2 11740000 V 27500000 2/3 AUTO AUTO
initial transponder DVB-S  12692000 V 19532000 1/2 AUTO AUTO
initial transponder DVB-S2 12692000 V 19532000 1/2 AUTO AUTO
>>> tune to: 11720:hC34S0:S0.0W:29500:
DVB-S IF freq is 1120000
Moving rotor from position 0 to position 19
Rotating..........completed.
>>> tune to: 11720:hC34S0:S0.0W:29500: (tuning failed)
Rotor already at position 19
>>> tune to: 11720:hC34S1:S0.0W:29500:
>>> tune to: 11720:hC34S1:S0.0W:29500: (tuning failed)
>>> tune to: 11740:vC23S0:S0.0W:27500:
DVB-S IF freq is 1140000
>>> tune to: 11740:vC23S0:S0.0W:27500: (tuning failed)
I see scan-s2 successfully moving the rotor - is this what you mean by adjusting the diseqc settings? Sorry to be a total newb, but I'm really confused as to what parameters I need to pass to scan-s2 to get it working. Is there a way for me to work out the diseqc settings? I'm basically hooked up to the Sky dish that was left on my house by the previous occupant so have no details of the setup (I'm in Norwich if that helps?).
Regards,
Euge
Euge
Postby cody » Mon Feb 14, 2011 6:45 am
hi Euge,
first of all by this:
Derrick wrote:Apparently you are trying to scan transponders from 19E.
Derrick meant that you're using "astra_scan-s2.conf" example from our driver package, which is for Astra 19.2E satellite and not for Astra 28.2E, which you're trying to lock. anyway, i believe the problem is very simple based on the information you provided:
1) you get lock with 'szap-s2' which means everything is setup correctly:
Code: Select all
2) 'scan-s2' doesn't work, because it seems to me you configuration file is not correct:
Code: Select all
because modulation can't be AUTO. please, after unsuccessful 'scan-s2' attempt check with 'dmesg | grep tbs6981fe" - i guess just error that modulation is unsupported will be reported. if so, please, consult "README" file from the Linux driver package to see proper 'scan-s2' configuration file settings.
regards,
Postby Euge » Mon Feb 14, 2011 7:50 am
Hi cody,
Thanks for the response. I've adjusted the configuration file as suggested in the README:
Code: Select all
S1 11720000 H 29500000 3/4 35 QPSK
S1 11740000 V 27500000 2/3 35 QPSK
S1 11758000 H 27500000 2/3 35 QPSK
S1 11778000 V 27500000 2/3 35 QPSK
S1 11798000 H 29500000 3/4 35 QPSK
S1 11817000 V 27500000 2/3 35 QPSK
S1 11836000 H 27500000 2/3 35 QPSK
S1 11856000 V 27500000 2/3 35 QPSK
S1 11876000 H 27500000 2/3 35 QPSK
S1 11895000 V 27500000 2/3 35 QPSK
S1 11914000 H 27500000 2/3 35 QPSK
S1 11934000 V 27500000 2/3 35 QPSK
S1 11954000 H 27500000 2/3 35 QPSK
S1 12051000 V 27500000 2/3 35 QPSK
S1 12129000 V 27500000 2/3 35 QPSK
S1 12148000 H 27500000 2/3 35 QPSK
S1 12168000 V 27500000 2/3 35 QPSK
S1 12226000 H 27500000 2/3 35 QPSK
S1 12246000 V 27500000 2/3 35 QPSK
S1 12422000 H 27500000 2/3 35 QPSK
S1 12480000 V 27500000 2/3 35 QPSK
S1 11973000 V 27500000 2/3 35 QPSK
S1 11992000 H 27500000 2/3 35 QPSK
S1 12012000 V 27500000 2/3 35 QPSK
S1 12032000 H 27500000 2/3 35 QPSK
S1 12070000 H 27500000 2/3 35 QPSK
S1 12090000 V 27500000 2/3 35 QPSK
S1 12110000 H 27500000 2/3 35 QPSK
S1 12188000 H 27500000 2/3 35 QPSK
S1 12207000 V 27500000 2/3 35 QPSK
S1 12266000 H 27500000 2/3 35 QPSK
S1 12285000 V 27500000 2/3 35 QPSK
S1 12304000 H 27500000 2/3 35 QPSK
S1 12324000 V 29500000 3/4 35 QPSK
S1 12344000 H 29500000 3/4 35 QPSK
S1 12363000 V 29500000 3/4 35 QPSK
S1 12382000 H 27500000 2/3 35 QPSK
S1 12402000 V 27500000 2/3 35 QPSK
S1 12441000 V 27500000 2/3 35 QPSK
S1 12460000 H 27500000 2/3 35 QPSK
S1 10714000 H 22000000 5/6 35 QPSK
S1 10729000 V 22000000 5/6 35 QPSK
S1 10744000 H 22000000 5/6 35 QPSK
S1 10758000 V 22000000 5/6 35 QPSK
S1 10788000 V 22000000 5/6 35 QPSK
S1 10803000 H 22000000 5/6 35 QPSK
S1 10818000 V 22000000 5/6 35 QPSK
S1 10832000 H 22000000 5/6 35 QPSK
S1 10847000 V 22000000 5/6 35 QPSK
S1 10862000 H 22000000 5/6 35 QPSK
S1 10876000 V 22000000 5/6 35 QPSK
S1 10891000 H 22000000 5/6 35 QPSK
S1 10906000 V 22000000 5/6 35 QPSK
S1 10921000 H 22000000 5/6 35 QPSK
S1 10936000 V 22000000 5/6 35 QPSK
S1 11222170 H 27500000 2/3 35 QPSK
S1 11223670 V 27500000 2/3 35 QPSK
S1 11259000 V 27500000 2/3 35 QPSK
S1 11261000 H 27500000 2/3 35 QPSK
S1 11307000 H 27500000 2/3 35 QPSK
S1 11307000 V 27500000 2/3 35 QPSK
S1 11343000 V 27500000 2/3 35 QPSK
S1 11344000 H 27500000 2/3 35 QPSK
S1 11390000 H 27500000 2/3 35 QPSK
S1 11390000 V 27500000 2/3 35 QPSK
S1 11426000 H 27500000 2/3 35 QPSK
S1 11426000 V 27500000 2/3 35 QPSK
S1 11469000 H 27500000 2/3 35 QPSK
S1 11488000 V 27500000 2/3 35 QPSK
S1 11508000 H 27500000 2/3 35 QPSK
S1 11527000 V 27500000 2/3 35 QPSK
S1 11546000 H 27500000 2/3 35 QPSK
S1 11565000 V 27500000 2/3 35 QPSK
S1 11585000 H 27500000 2/3 35 QPSK
S1 11603850 V 27500000 2/3 35 QPSK
S1 11623000 H 27500000 2/3 35 QPSK
S1 11642000 V 27500000 2/3 35 QPSK
S1 11661540 H 27500000 2/3 35 QPSK
S1 11680770 V 27500000 2/3 35 QPSK
S1 12524000 H 27500000 2/3 35 QPSK
S1 12524000 V 27500000 2/3 35 QPSK
S1 12560000 H 27500000 2/3 35 QPSK
S1 12560000 V 27500000 2/3 35 QPSK
S1 12596000 V 27500000 2/3 35 QPSK
S1 12607000 H 27500000 3/4 35 QPSK
S1 12629000 V 6111000 3/4 35 QPSK
S1 12692000 V 19532000 1/2 35 QPSK
It's still not getting successful scans even though I'm no longer on 'AUTO' modulation:
Code: Select all
mediacentre scan-s2 # ./scan-s2 -a2 ../Astra-28.2E -r 28.2E
scanning ../Astra-28.2E
initial transponder DVB-S  11720000 H 29500000 3/4 35 QPSK
initial transponder DVB-S  11740000 V 27500000 2/3 35 QPSK
initial transponder DVB-S  11758000 H 27500000 2/3 35 QPSK
initial transponder DVB-S  11778000 V 27500000 2/3 35 QPSK
initial transponder DVB-S  11798000 H 29500000 3/4 35 QPSK
initial transponder DVB-S  12596000 V 27500000 2/3 35 QPSK
initial transponder DVB-S  12607000 H 27500000 3/4 35 QPSK
initial transponder DVB-S  12629000 V 6111000 3/4 35 QPSK
initial transponder DVB-S  12692000 V 19532000 1/2 35 QPSK
>>> tune to: 11720:hC34M2O35S0:S0.0W:29500:
>>> tune to: 11720:hC34M2O35S0:S0.0W:29500: (tuning failed)
>>> tune to: 11740:vC23M2O35S0:S0.0W:27500:
>>> tune to: 11758:hC23M2O35S0:S0.0W:27500:
DVB-S IF freq is 1158000
>>> tune to: 11758:hC23M2O35S0:S0.0W:27500: (tuning failed)
>>> tune to: 11778:vC23M2O35S0:S0.0W:27500:
Code: Select all
produces only:
Code: Select all
tbs6981fe: software version is 1.95
Any idea where I go from here?
Euge
Postby cody » Wed Feb 16, 2011 7:04 am
ok, let's try the simplest thing that comes to mind, according to your logs you can lock the following with 'szap-s2':
Code: Select all
and 'scan-s2' configuration line for the above should look like:
Code: Select all
S1 11773000 H 22000000 5/6 35 QPSK
so, if you put the above line in let's say file called "test_scan-s2.conf" and run:
# scan-s2 test_scan-s2.conf
what did happen?
Postby Euge » Thu Feb 17, 2011 4:59 am
Hi cody,
Doing as you suggested gives:
Code: Select all
mediacentre scan-s2 # ./scan-s2 -a2 test_scan-s2.conf
scanning test_scan-s2.conf
Done.
However, I tried rebooting the PC and then re-trying the above and get this:
Code: Select all
>>> parse_section, section number 0 out of 0...!
service_id = 0x189D
pmt_pid = 0x100
service_id = 0x189E
pmt_pid = 0x102
service_id = 0x18AB
pmt_pid = 0x103
service_id = 0x18AF
pmt_pid = 0x10A
service_id = 0x18BF
pmt_pid = 0x10B
service_id = 0x18C5
pmt_pid = 0x10C
service_id = 0x18CF
pmt_pid = 0x10D
service_id = 0x18D9
pmt_pid = 0x10E
  VIDEO     : PID 0x1388
  AUDIO     : PID 0x1389
  AUDIO     : PID 0x138A
  TELETEXT  : PID 0x138B
  OTHER     : PID 0x0F06 TYPE 0x0B
  OTHER     : PID 0x0F07 TYPE 0x0B
  OTHER     : PID 0x0F08 TYPE 0x0B
  OTHER     : PID 0x0F09 TYPE 0x0B
  SUBTITLING: PID 0x138C
  OTHER     : PID 0x0F00 TYPE 0x05
  OTHER     : PID 0x0F01 TYPE 0x05
  OTHER     : PID 0x0F02 TYPE 0x05
  OTHER     : PID 0x0F03 TYPE 0x05
  OTHER     : PID 0x0F04 TYPE 0x05
  OTHER     : PID 0x0911 TYPE 0x05
  OTHER     : PID 0x090C TYPE 0x05
  OTHER     : PID 0x090D TYPE 0x05
  OTHER     : PID 0x090E TYPE 0x05
  VIDEO     : PID 0x13EC
  AUDIO     : PID 0x13ED
  AUDIO     : PID 0x13EE
  TELETEXT  : PID 0x13EF
  SUBTITLING: PID 0x13F0
  OTHER     : PID 0x0922 TYPE 0x05
  VIDEO     : PID 0x1450
  AUDIO     : PID 0x1451
  TELETEXT  : PID 0x1453
  OTHER     : PID 0x0928 TYPE 0x05
  OTHER     : PID 0x090F TYPE 0x05
  OTHER     : PID 0x0913 TYPE 0x05
  OTHER     : PID 0x0914 TYPE 0x05
  OTHER     : PID 0x0915 TYPE 0x05
  VIDEO     : PID 0x1450
  AUDIO     : PID 0x1451
  AUDIO     : PID 0x1452
  SUBTITLING: PID 0x1454
  VIDEO     : PID 0x1518
  AUDIO     : PID 0x1519
  AUDIO     : PID 0x151A
  TELETEXT  : PID 0x151C
  SUBTITLING: PID 0x151B
  VIDEO     : PID 0x170C
  AUDIO     : PID 0x170D
  TELETEXT  : PID 0x170F
  SUBTITLING: PID 0x1710
  VIDEO     : PID 0x1644
  AUDIO     : PID 0x1645
  TELETEXT  : PID 0x1647
  SUBTITLING: PID 0x1648
  VIDEO     : PID 0x16A8
  AUDIO     : PID 0x16A9
  TELETEXT  : PID 0x16AB
  SUBTITLING: PID 0x16AC
>>> parse_section, section number 1 out of 1...!
0x07FD 0x18CF: pmt_pid 0x010D BSkyB -- BBC 1 East (W) (running)
0x07FD 0x18D9: pmt_pid 0x010E BSkyB -- BBC 1 CI (running)
>>> parse_section, section number 0 out of 1...!
0x07FD 0x189D: pmt_pid 0x0100 BSkyB -- BBC 1 London (running)
0x07FD 0x189E: pmt_pid 0x0102 BSkyB -- BBC 2 England (running)
0x07FD 0x18AB: pmt_pid 0x0103 BSkyB -- BBC TES 3 (running)
0x07FD 0x18AD: pmt_pid 0x0000 BSkyB -- CBBC Channel (not running)
0x07FD 0x18AF: pmt_pid 0x010A BSkyB -- BBC THREE (running)
0x07FD 0x18BF: pmt_pid 0x010B BSkyB -- Channel 5 (running)
0x07FD 0x18C5: pmt_pid 0x010C BSkyB -- BBC 1 West (running)
Network Name 'ASTRA'
dumping lists (9 services)
BBC 2 England;BSkyB:10773:hC56M2O35S0:S28.2E:22000:5100:5101=eng,5102=NAR:5103:0:6302:2:2045:0
BBC TES 3;BSkyB:10773:hC56M2O35S0:S28.2E:22000:5200:5201=eng:5203:0:6315:2:2045:0
BBC THREE;BSkyB:10773:hC56M2O35S0:S28.2E:22000:5200:5201=eng,5202=NAR:5203:0:6319:2:2045:0
Channel 5;BSkyB:10773:hC56M2O35S0:S28.2E:22000:5400:5401=eng,5402=NAR:5404:0:6335:2:2045:0
BBC 1 West;BSkyB:10773:hC56M2O35S0:S28.2E:22000:5900:5901=eng:5903:0:6341:2:2045:0
BBC 1 East (W);BSkyB:10773:hC56M2O35S0:S28.2E:22000:5700:5701=eng:5703:0:6351:2:2045:0
BBC 1 CI;BSkyB:10773:hC56M2O35S0:S28.2E:22000:5800:5801=eng:5803:0:6361:2:2045:0
Done.
Unfortunately however this only worked the once. I ran scan-s2 again and the output returned to:
Code: Select all
Done.
This is all I'm able to get from the card - I tried rebooting again and got the same behaviour - it scans once and thereafter will not scan - is this a fault with the card or the scan-s2 software?
Thanks for your help so far - I'm hoping you're able to shed light on what's happening.
Regards,
Euge
Euge
Postby Euge » Fri Feb 18, 2011 6:07 pm
Hi cody,
A thought occurred last night - could the behaviour I'm seeing be a result of not enough power being supplied to the LNB via the card over the satellite cable? Do I need to connect up some of the additional power connectors available on the card to my PSU? Or am I completely off track with this suggestion? It's really confusing that the scan works immediately after a reboot but fails thereafter.
Regards,
Euge
Euge
Postby cody » Sun Feb 20, 2011 8:55 pm
hi Euge,
sorry that i wasn't able to reply earlier, but we're going to CeBIT 2011 and i'm busy preparing for it. anyway, if 'szap-s2' works any time, but 'scan-s2' only some times then it could be indeed some hardware fault with data transfer on the board. i can suggest few things just to confirm it for sure before proceed with replacing your board with new one - is it possible for you to test the board in Windows - just to completely rule out some software issue in Linux? if not, is it possible to give me remote access to your Linux system - just to test it myself (you can send me the details via PM).
thanks,
Postby Euge » Tue Feb 22, 2011 8:23 pm
hi cody,
I'll have a dig around in my garage - I think there's an old windows PC of my Dad's in there somewhere though I don't know if it's got a PCI-E 1.0 slot - if it has then I'll see if I can get around to testing the card in it this weekend (I'm at a PHP conference in London later this week so time is a bit tight for me too at the moment).
Regards,
Euge
Euge
Users browsing this forum: Baidu [Spider], Google [Bot] and 0 guests
