Is CI-module supported in MediaPortal?
Postby superbaton » Tue Nov 29, 2011 9:47 pm
Hallo,
Is CI module from TBS5980 supported in MediaPortal 1.2.1? I tried to access my my CAM module menu, but MP says it cannot access it.
In TBSViewer everything is OK. I preffer to use MP rather than TBSViewer.
If CI module is not supported in MP, is any chance to have it working in MP ??
Best regards,
superbaton
superbaton
Re: Is CI-module supported in MediaPortal?
Postby smile » Fri Dec 02, 2011 3:04 pm
Hi superbaton
we are contacting MediaPortal ,if there is any progress,we will get back to you as soon as possible.
Thanks!
smile
Postby superbaton » Mon Dec 05, 2011 3:24 pm
Thanks :D
superbaton
Postby superbaton » Thu Dec 08, 2011 7:03 pm
Under link below you can find patch for MediaPortal 1.2.1 with support of TBS cards also with CI support.
http://forum.team-mediaportal.com/general-development-no-feature-request-here-48/tbs-ci-cam-support-other-improvements-103276/
This is of course test version, but it is worth to try if you would like to use TBS 5980 with CI support in MediaPortal.
It is working for me. I use TBS 5980 with conax CAM (nCAM HD module)
You can also hepl to improve this patch by testing it and post your log files on MediaPortal forum :D
Best regards,
superbaton
superbaton
