5881 - TV playback hangs when IR command is received
Postby klosz007 » Fri Jun 02, 2017 10:47 pm
TBS5881 + Windows 10 x64 + DVB-C driver 1.0.0.5 for Win10 + local cable operator's CAM module
During TV playback, when IR remote control command is received (any button pressed, sometimes after just one button press, sometimes after a few presses), one of the following happens:
- TV playback stops (no audio, video frozen) for ~15 seconds, then resumes to normal
or
- audio disappears, TV becomes jerky/slideshow for ~15 seconds, then resumes to normal
or
- tuner hangs completely and has to be powercycled to restore operation
Same thing happens in DVBViewer or in DVBDream. Tested on two different PCs. Sometimes even IR command from another remote (TV, AV receiver) is causing this behavior.
Remote functions generally work but have destructive effect on TV playback. TV playback is rock-stable until I'm trying to use remote control.
Has anyone experienced this ?
I suspect the issue is in faulty tuner or in BDA driver. Even with no driver installed for VHID device, the issue is still the same.
klosz007
Re: 5881 - TV playback hangs when IR command is received
Postby crazycat » Fri Aug 04, 2017 1:20 pm
This bug in Cypress FX2 firmware (uploaded by driver on init).
