MOI-V Streaming Server // SUPPORT!?
Postby dam72 » Wed Jun 07, 2017 7:10 pm
Hi Guys,
we have bought a MOI-V Streaming Server with several DVB-S2 and DVB-C cards. The Server was shipped without any information or handbook. How the hell shall we start to use/configure the server.
When we boot up we either see a centOS login, we don´t know the logon data, or on webGUI we see on Port 80 SuperMicro login...
I would assume a WebGUI to configure tuner and Tvheadend...
dam72
Re: MOI-V Streaming Server // SUPPORT!?
Postby xiaocao » Thu Jun 08, 2017 6:11 pm
hi ,
please use command "pidof httpd" to see if webui login successfully .
you can write email to jack@tbsdtv.com and tell me the remote control via ssh connect or teamviewer.
i will fix it .
best regards!
xiaocao
Postby dam72 » Thu Jun 08, 2017 8:42 pm
Hi jack,
thanks I received in the meantime the right instruction how to log in. I wrote you also an Email.
I´d like to use tvheadend, I could get it running in the meantime. I am missing the "IPTV" tab, because I must stream the single services as udp multicast. With the tvheadend version I know this is possible to use udp multicast, why not with yours? Can you advise how to upgrade tvheadend?
dam72
Postby xiaocao » Tue Jun 13, 2017 12:42 pm
hi,
Tvheadend is a TV streaming server and digital video recorder.
It supports the following inputs:
DVB-C(2)
DVB-T(2)
DVB-S(2)
ATSC
SAT>IP
HDHomeRun
IPTV
UDP
HTTP
It supports the following outputs:
HTTP
HTSP (own protocol)
SAT>IP
best regards!
xiaocao
Postby xiaocao » Tue Jun 13, 2017 12:46 pm
hi ,
if you want to streaming via udp protocol ,you can consider dvblast which is a simple and powerful MPEG-2/TS demux and streaming application .
please refer to this link :
https://github.com/gfto/dvblast
best regards!
xiaocao
Postby dam72 » Tue Sep 05, 2017 10:55 pm
Hi Xiaocao,
in the meantime I have it up. I have a very stupid problem, I couldn´t resolve. I want to start my dvblast adapaters with -W -Y parameter to forward also ECM/EMM. Where the hell I have to add this, to get them started with these two parameters?
e.g. it´s starts like this:
dvblast_12 -f 130000000 -s 6900000 -m qam_256 -a 12 -c /usr/local/tbs/apache2.4.3/htdocs/www/configs/dvblast/adapter_12/dvblast_c.conf -5 DVBC_ANNEX_A
BUT I NEED IT LIKE THIS:
dvblast_12 -f 130000000 -s 6900000 -m qam_256 -a 12 -W -Y -c /usr/local/tbs/apache2.4.3/htdocs/www/configs/dvblast/adapter_12/dvblast_c.conf -5 DVBC_ANNEX_A
Thanks for your help!
dam72
Postby xiaocao » Wed Sep 06, 2017 3:57 pm
hi,
add in this file
/usr/local/tbs/apache2.4.3/htdocs/www/cgi-bin/streaming.cgi
/usr/bin/dvblast_${adapter} -f $fre -s $sr -v $pol -a $adapter -c $cfgfile -S $port -5 DVBS > /dev/null 2>&1 &
to
/usr/bin/dvblast_${adapter} -f $fre -s $sr -v $pol -a $adapter -c $cfgfile -S $port -5 DVBS -W -Y > /dev/null 2>&1 &
best regards!
xiaocao
Postby dam72 » Wed Sep 06, 2017 5:17 pm
I changed already in almost all cgi scripts all calls with dvblast with addtional -W -Y but it doesn´t help!? Also the line you proposed a changed few days and today again... no change after reboot!
It looks the start script a different file... Which one!?
This is the reason why I wrote here.
SOLVED: Changes need to be edited in /usr/bin/rundvblast, then it works...
dam72
Return to Off topics
