Ubuntu 18.04 TBS 6285 driver install fails at 'make'
Postby andrewj720 » Sun Apr 15, 2018 4:45 am
I'm tying to install Linux drivers for TBS 6285.
I've tried the open source drivers and TBS's own proprietary ones, obtained from TBS website.
When I try and 'make' I get the following output:
root@lounge-server:~/tbs/linux-tbs-drivers# make -j5
make -C /root/tbs/linux-tbs-drivers/v4l
make[1]: Entering directory '/root/tbs/linux-tbs-drivers/v4l'
make -C firmware prep
creating symbolic links...
make[2]: Entering directory '/root/tbs/linux-tbs-drivers/v4l/firmware'
make[2]: Leaving directory '/root/tbs/linux-tbs-drivers/v4l/firmware'
make -C firmware
make[2]: Nothing to be done for 'default'.
Kernel build directory is /lib/modules/4.15.0-15-generic/build
make -C /lib/modules/4.15.0-15-generic/build SUBDIRS=/root/tbs/linux-tbs-drivers/v4l  modules
make[2]: Entering directory '/usr/src/linux-headers-4.15.0-15-generic'
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/tda18271.o
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/saa7146.o
  CC [M]  /root/tbs/linux-tbs-drivers/v4l/saa7146_video.o
  CC [M]  /root/tbs/linux-tbs-drivers/v4l/saa7146_vbi.o
  CC [M]  /root/tbs/linux-tbs-drivers/v4l/saa716x_pci.o
  CC [M]  /root/tbs/linux-tbs-drivers/v4l/saa716x_i2c.o
  CC [M]  /root/tbs/linux-tbs-drivers/v4l/saa716x_cgu.o
/root/tbs/linux-tbs-drivers/v4l/saa7146_video.c: In function 'video_init':
/root/tbs/linux-tbs-drivers/v4l/saa7146_video.c:1307:2: error: implicit declaration of function 'init_timer'; did you mean 'init_timers'? [-Werror=implicit-function-declaration]
  init_timer(&vv->video_q.timeout);
  init_timers
/root/tbs/linux-tbs-drivers/v4l/saa7146_video.c:1308:31: error: assignment from incompatible pointer type [-Werror=incompatible-pointer-types]
  vv->video_q.timeout.function = saa7146_buffer_timeout;
/root/tbs/linux-tbs-drivers/v4l/saa7146_video.c:1309:21: error: 'struct timer_list' has no member named 'data'
  vv->video_q.timeout.data     = (unsigned long)(&vv->video_q);
scripts/Makefile.build:332: recipe for target '/root/tbs/linux-tbs-drivers/v4l/saa7146_video.o' failed
make[3]: *** [/root/tbs/linux-tbs-drivers/v4l/saa7146_video.o] Error 1
make[3]: *** Waiting for unfinished jobs....
/root/tbs/linux-tbs-drivers/v4l/saa7146_vbi.c: In function 'vbi_workaround':
/root/tbs/linux-tbs-drivers/v4l/saa7146_vbi.c:117:6: error: implicit declaration of function 'signal_pending'; did you mean 'timer_pending'? [-Werror=implicit-function-declaration]
   if(signal_pending(current)) {
      timer_pending
/root/tbs/linux-tbs-drivers/v4l/saa7146_vbi.c: In function 'vbi_init':
/root/tbs/linux-tbs-drivers/v4l/saa7146_vbi.c:368:2: error: implicit declaration of function 'init_timer'; did you mean 'init_timers'? [-Werror=implicit-function-declaration]
  init_timer(&vv->vbi_q.timeout);
  init_timers
/root/tbs/linux-tbs-drivers/v4l/saa7146_vbi.c:369:29: error: assignment from incompatible pointer type [-Werror=incompatible-pointer-types]
  vv->vbi_q.timeout.function = saa7146_buffer_timeout;
/root/tbs/linux-tbs-drivers/v4l/saa7146_vbi.c:370:19: error: 'struct timer_list' has no member named 'data'
  vv->vbi_q.timeout.data     = (unsigned long)(&vv->vbi_q);
/root/tbs/linux-tbs-drivers/v4l/saa7146_vbi.c: In function 'vbi_open':
/root/tbs/linux-tbs-drivers/v4l/saa7146_vbi.c:418:32: error: assignment from incompatible pointer type [-Werror=incompatible-pointer-types]
  fh->vbi_read_timeout.function = vbi_read_timeout;
/root/tbs/linux-tbs-drivers/v4l/saa7146_vbi.c:419:22: error: 'struct timer_list' has no member named 'data'
  fh->vbi_read_timeout.data = (unsigned long)file;
scripts/Makefile.build:332: recipe for target '/root/tbs/linux-tbs-drivers/v4l/saa7146_vbi.o' failed
make[3]: *** [/root/tbs/linux-tbs-drivers/v4l/saa7146_vbi.o] Error 1
/root/tbs/linux-tbs-drivers/v4l/saa716x_pci.c: In function 'saa716x_enable_msix':
/root/tbs/linux-tbs-drivers/v4l/saa716x_pci.c:49:8: error: implicit declaration of function 'pci_enable_msix'; did you mean 'pci_enable_msi'? [-Werror=implicit-function-declaration]
  ret = pci_enable_msix(pdev, saa716x->msix_entries, SAA716x_MSI_MAX_VECTORS);
        pci_enable_msi
scripts/Makefile.build:332: recipe for target '/root/tbs/linux-tbs-drivers/v4l/saa716x_pci.o' failed
make[3]: *** [/root/tbs/linux-tbs-drivers/v4l/saa716x_pci.o] Error 1
Makefile:1552: recipe for target '_module_/root/tbs/linux-tbs-drivers/v4l' failed
make[2]: *** [_module_/root/tbs/linux-tbs-drivers/v4l] Error 2
make[2]: Leaving directory '/usr/src/linux-headers-4.15.0-15-generic'
make[1]: Leaving directory '/root/tbs/linux-tbs-drivers/v4l'
make: *** [all] Error 2
Any ideas how to get past this?
andrewj720
Re: Ubuntu 18.04 TBS 6285 driver install fails at 'make'
Postby steven » Mon Apr 16, 2018 9:42 am
Please have a try with older kernel first for kernle 4.15 we will add support soon
Postby andreril » Tue Jun 12, 2018 6:05 pm
steven Wrote:Hi
also keen to understand when support for later kernels will be available?
Do you have a matrix of what driver versions are supported with what kernels?
andreril
Postby steven » Wed Jun 13, 2018 9:13 am
#wget http://www.tbsdtv.com/download/document/linux/media_build-2018-05-25.tar.bz2
#tar jxvf media_build-2018-05-25.tar.bz2
#cd media_build
#./install.sh
#reboot
Postby andrewj720 » Sun Aug 05, 2018 9:02 pm
steven Wrote:Hi
#cd media_build
#./install.sh
#reboot
Thanks Steven, I will try this today.
andrewj720
Postby kosacik » Mon Aug 27, 2018 2:28 pm
I tried them on Ubuntu 18.04 for TBS6982SE. Did not work with standard kernel 4.15 something, even when intstallation worked fine, drivers
does not work. (lsdvb gives nothing). Can You provide me drivers for my card too? I do not want to use old kernel. Thank you.
steven Wrote:Hi
#cd media_build
#./install.sh
#reboot
kosacik
Postby rubenscg » Thu Oct 18, 2018 10:52 pm
hello,
the solucion for you,
try install drivers on ubuntu server 18.04 1 LTS with this commands:
apt-get install git
apt-get install build-essential patchutils libproc-processtable-perl linux-headers-`uname –r` git linux-source
apt-get install cmake
cd /usr/src
cd media_build
uname -a
rm -rf /lib/modules/$(uname -r)/extra
rm -rf /lib/modules/$(uname -r)/kernel/drivers/media
rm -rf /lib/modules/$(uname -r)/kernel/drivers/staging/media
rm -Rf /lib/modules/4.15.0-29-generic/kernel/drivers/media
make dir DIR=../media
make remove
make clean
make allyesconfig
make -j4
make install
cd
reboot
dmesg | grep frontend
wget http://www.tbsdtv.com/download/document ... .0.tar.bz2
tar jxvf tbs-tuner-firmwares_v1.0.tar.bz2 -C /lib/firmware/
Regards
rubenscg
Postby genesis74 » Fri Dec 07, 2018 2:52 pm
Hi there,
I was very happy to find this thread while having problems installing the drivers for my TBS 6281. I followed the instructions in the last post on my Ubuntu 18.04.1 system successfully, now my TBS6281 is working perfectly with tvheadend.
But: After every update of the Linux kernel the driver is gone and I have to go through the whole installation again. Is there any way to automate this?
Phil
genesis74
Postby smf » Sat Dec 29, 2018 6:05 pm
I am experiencing the same problems trying to make the drivers for a TBS6280 and Ubuntu 18.04. I can see the problem is due to the change in the kernel timer spec but don't have enough experience to fix it. Can anyone help please?
smf
Postby AdamJacobs » Wed Jan 02, 2019 1:05 am
I am having a very similar problem with a TBS 6284.
I tried the link in Steven's post of 13 June, and that seems to have worked for me. However, I noticed when installing it there were all sorts of warnings about it being an experimental package and not for production use.
Should I be worried by those?
I would also love to know the answer to Phil's question of 7 December: am I going to have to reinstall them every time I update my Linux kernel? Because to be honest, that's a bit of a pain, and if there is some way round that, it would be really appreciated.
Adam
AdamJacobs
