TBS6281 install issue
Postby mollcons » Tue Jul 17, 2018 12:44 am
After apparently successfully installing the drivers, when I try to perform the standard tests, one in particular will not go further than the initial display:
[root@saruman root]# lsdvb
Version: 0.0.4
Copyright (C) Manu Abraham
SAA716x Budget (1131:7160 6281:1) on PCI Domain:0 Bus:2 Device:0 Function:0
DEVICE:0 ADAPTER:0
where the command freezes (until I Ctrl-C the display).
How do I overcome this?
mollcons
Re: TBS6281 install issue
Postby daowei » Tue Jul 17, 2018 12:03 pm
Did you mean you have installed driver successfully, but no adapter?
if you want to check tuner card is detectd or not, please try this command:
$ lspci -vvv | grep6281
If you want to check if driver is ready or not, please try this:
# ls /dev/dvb
or
# dmesg | grep frontend
Or maybe it's easier for you to install tuner card to a windows system and test.
Postby mollcons » Wed Jul 18, 2018 4:46 pm
The tests I already did are as follows:
[root@saruman root]# dmesg | grep -i saa716
[ 6.654442] saa716x_core: loading out-of-tree module taints kernel.
[ 6.654530] saa716x_core: module verification failed: signature and/or required key missing - tainting kernel
[ 6.699372] dvbdev: DVB: registering new adapter (SAA716x dvb adapter)
[ 6.891229] SAA716x Budget 0000:02:00.0: TurboSight TBS 6281 MAC[0]=ff:ff:ff:ff:ff:ff
[ 6.891232] SAA716x Budget 0000:02:00.0: DVB: registering adapter 0 frontend 0 (TurboSight TBS 6281 DVB-T/T2/C)...
[ 6.892363] dvbdev: DVB: registering new adapter (SAA716x dvb adapter)
[ 7.061919] SAA716x Budget 0000:02:00.0: TurboSight TBS 6281 MAC[1]=ff:ff:ff:ff:ff:ff
[ 7.061922] SAA716x Budget 0000:02:00.0: DVB: registering adapter 1 frontend 0 (TurboSight TBS 6281 DVB-T/T2/C)...
[ 1482.937421] media(OE) si2168(OE) snd_hda_intel k8temp snd_hda_codec snd_hda_core snd_hwdep snd_seq sp5100_tco snd_seq_device i2c_piix4 snd_pcm saa716x_tbs_dvb(OE) cx24117(OE) tas2101(OE) saa716x_core(OE) dvb_core snd_timer snd i2c_mux soundcore parport_pc parport shpchp wmi radeon firewire_ohci firewire_core ata_generic pata_acpi serio_raw i2c_algo_bit crc_itu_t drm_kms_helper pata_atiixp ttm r8169 drm mii
[root@saruman root]# grep saa716x /etc/modprobe.d/*
/etc/modprobe.d/saa716x_budget.conf:options saa716x_budget int_type=1
[root@saruman root]# lspci -v | grep --after-context=10 7160
02:00.0 Multimedia controller: Philips Semiconductors SAA7160 (rev 03)
Subsystem: Device 6281:0001
Flags: bus master, fast devsel, latency 0, IRQ 16, NUMA node 0
Memory at fdd00000 (64-bit, non-prefetchable) [size=1M]
Capabilities: [50] Express Endpoint, MSI 00
Capabilities: [100] Vendor Specific Information: ID=0000 Rev=0 Len=088 <?>
Kernel driver in use: SAA716x Budget
Kernel modules: saa716x_tbs_dvb
ls -al /dev/dvb
total 0
drwxr-xr-x. 4 root root 80 Jul 15 21:04 .
drwxr-xr-x. 23 root root 4300 Jul 15 21:04 ..
drwxr-xr-x. 2 root root 120 Jul 15 21:04 adapter0
drwxr-xr-x. 2 root root 120 Jul 15 21:04 adapter1
Version: 0.0.4
DEVICE:0 ADAPTER:0
.... which is where the response has frozen.
mollcons
Postby mollcons » Sat Aug 18, 2018 6:30 am
Any answers?
mollcons
Postby daowei » Mon Aug 20, 2018 1:03 pm
From your information, the driver should be ready now. Please install a streaming software to test, i recommend you DVBlast.
Which signal do you have now? DVBT/T2 or DVBC?
For DVBT/T2, you can try this:
$ dvblast -f 474000000 -b 8 -a 0 -5 DVBT
$ dvblast -f 650000000 -b 8 -a 1 -5 DVBT2
For DVBC, please try:
$ dvblast -f 712000000 -s 6900000 -5 DVBC_ANNEX_A -a 0
