tbs2604 firmware Version 1.0.10.
Postby webmotions » Sat Sep 01, 2018 6:15 pm
Hi, my firmware version is in the subject.
if you reset the settings, the encoder becomes to be unusable. The message "BFrameNum should be integer in 1-3" appears. That's the end of this encoder. Consequently HDMI main stream settings can't be saved. Have you ever done a basic, very basic test ?
Regards
webmotions
Re: tbs2604 firmware Version 1.0.10.
Postby daowei » Sat Oct 06, 2018 11:40 am
webmotions Wrote:Hi, my firmware version is in the subject.
Regards
This message reminds you that you must enter some valuse for "BFrameNum" blank. Your firmware is too olde, the latest is version 1.1.87, we have many improvements in this version, Please try.
Upgrade setps:
1> Unpack the zip file "tbs2603_firmware_v1.1.87.zip"
2> Upload the file "update.tar.bz2"
3> Start to upgrade until it says "upgrade is successful"
Any question please update to me or write to me, my e-mail "daowei@tbsdtv.com".
Postby daowei » Sat Oct 06, 2018 11:45 am
Regards
Upgrade setps:
Again, the new firmware please check my attachment.
firmware v1.1.87 for TBS2603
(3.04 MiB) Downloaded 253 times
