Tbs 6522
Tbs 6522
Postby Farjam » Thu Jan 09, 2020 6:53 pm
Hi. Don't be tired. I have a 6522 card. Other drivers and software are working properly but when I log into tbs iptool software I get this error and can't use the capabilities of this software. Error: onok m_pksCtrl failed. Please help me thanks a lot.
Farjam
Re: Tbs 6522
Postby smile » Fri Jan 10, 2020 4:12 pm
HI
whether the card work on the DVBS mode?
Best Regards
smile
Re: Tbs 6522
Postby Farjam » Fri Jan 10, 2020 5:35 pm
Hi. Yes it works properly I can watch satellite channels and TV programs. I use the first port that has the DVB-S2X. I set the change mode tool values ​​as: Tuner 1: DVB-S/S2 and Tuner 0: DVB-C
Farjam
Re: Tbs 6522
Postby smile » Mon Jan 13, 2020 10:17 am
Could you change the two tuner to DVBS mode? i want to check if the tools select the DVBC channel to make the iptools error.
smile
Re: Tbs 6522
Postby Farjam » Mon Jan 13, 2020 9:46 pm
Yes my tuner pair is working properly. I have a question: Before logging into tbs ip data software do I have to select the device I need to select tuner 1 that I have connected to the satellite dish or tuner 0 that does not have satellite cable? When I use Tuner 2 then do I have to choose Tuner 2 before logging in? Or should both tuners be connected to the satellite at the same time?
Farjam
Re: Tbs 6522
Postby smile » Wed Jan 15, 2020 2:59 pm
HI
We will update the tools to fix this bug.
Best Regards
smile
Re: Tbs 6522
Postby Farjam » Wed Jan 15, 2020 6:31 pm
Notice also this picture. I installed the card on another computer but this time it did not error appear when logging into the software. I installed the card in Windows 7 Is it possible to fix the problem with installing in Windows 10?How long the update will take. Thanks
Farjam
Re: Tbs 6522
Postby Farjam » Wed Jan 15, 2020 9:53 pm
This is also the case in Windows 10. In Windows 10, I also get a control package error as soon as tbs ipdata runs
Win 10 pro 64bit
Farjam
Re: Tbs 6522
Postby Farjam » Sat Jan 25, 2020 12:37 am
[quote="smile"]HI
Best Regards
is anybody here? How long do I have to wait for the update? I had a hard time getting this card. 3 years ago you launched it but you didn't fix the software problems.
Farjam
Re: Tbs 6522
Postby steven » Thu Jan 30, 2020 10:25 am
Hi Sir
Sorrt that it is our chinese new year vacation now , when we start work will check this ASAP
