nvidia jetson tbs drivers
Postby teknomemo » Mon May 25, 2020 5:06 pm
Hi, i want to install tbs drivers for my tbs 5520se dvb-s2 usb device.
i have jetson nano (B01)
ubuntu 18.04
kernel 4.9.140
I am use this method :
wget http://www.tbsdtv.com/download/document ... 01.tar.bz2
sudo rm -rf /lib/modules/uname -r/kernel/drivers/media/
tar jxvf media_build-2019-11-01.tar.bz2
cd media_build
./install.sh
but, give error :
/abc/tbs/media_build/v4l/tw686x-core.c:89:29: error: initialization from incompatible pointer type [-Werror=incompatible-pointer-types]
module_param_call(dma_mode, tw686x_dma_mode_set, tw686x_dma_mode_get,
how can fix it ?
thanks …
teknomemo
Re: nvidia jetson tbs drivers
Postby steven » Mon May 25, 2020 5:25 pm
Hi Sir
# wget http://www.tbsdtv.com/download/document/linux/media_build-2020-01-02.tar.bz2
#tar jxvf media_build-2020-01-02.tar.bz2
#cd media_build
#./install.sh
#reboot
Postby teknomemo » Mon May 25, 2020 5:58 pm
thanks for quicly answer,
I've tried , but i think same error :
./include/linux/moduleparam.h:230:24: note: in definition of macro 'module_param_call'
{ .flags = 0, .set = _set, .get = _get }; \
/abc/tbs/media_build/v4l/tw686x-core.c:89:29: note: (near initialization for '__param_ops_dma_mode.set')
/abc/tbs/media_build/v4l/tw686x-core.c:89:50: error: initialization from incompatible pointer type [-Werror=incompatible-pointer-types]
./include/linux/moduleparam.h:230:37: note: in definition of macro 'module_param_call'
please help me !
teknomemo
