problem with media center
Postby fearsomebows » Wed Mar 16, 2011 2:38 am
hi i cant get media center to even see my tuner card 6920 just come's up with tuner not compatible .any help would be greatly appreciated.
fearsomebows
Re: problem with media center
Postby steven » Wed Mar 16, 2011 9:35 am
Are you sure 6920 is work well with dvbdream or tbsview,to make sure that 6920 is ok.
if 6920 is ok with dvbdream ,you can do as https://shop.tbsdtv.com/forum/viewtopic.php?f=2&t=78
thanks
Postby fearsomebows » Wed Mar 28, 2012 3:34 am
no windows does not even reconise the tuner card it say's it is not compatable. im running windows vista and dvb works just about ok .
fearsomebows
Postby steven » Wed Mar 28, 2012 10:15 am
This topic will help you:
http://www.tbsdtv.com/forum/viewtopic.php?f=2&t=78
http://answers.microsoft.com/en-us/windows/forum/windows_7-tv/tbs-6920-pci-e-dvb-s2-fta-satellite-tv-tuner-card/b203357a-ed38-4208-86dc-3424d420d226?msgId=1a5c1828-4291-4e21-89b6-54bfd10c3168
No I found that before hand, windows will not recognise the card is getting a signal. If i manually select the source i can tune it in but i have to manually scan for BBC HD and BBC1 HD on dvb-s2.
So it is like that you need to config it by yourself.
