TBS 6921 v23 problem with saveral transporders.
Postby ashdodmiracle » Sun Mar 27, 2011 10:43 pm
Recently i bought TBS 6921 with a goal to upgrade from pci to pci-e.
Just I instaled 6921 instead my 8920, I found that some my favorites channel's gone.
Here I will Inform about a not working / badly working transporders.
Astra 1E/4A at 4.8°E Tisa1 = 12672.00 H 3300 3/4 QPSK work ok (level 10% quality 50%)
Eurobird 9A at 9.0°E Fashion One (USA) = 12034.00 V 27500 3/4 8PSK lock, but picture is freezes (level 50% quality 70%)
Both tranporders perfectly works with TBS8920, but has a problems on TBS6921. (not depends on aplication, DVBViever, DVBdream, TBSviever - same result for all)
I use Windows 7 Ultimate x64 bit + driver from cd 2.0.0.4. (i tried a new one 2.0.0.5, but unsuccessful)
Is this the problem of TBS 6921 driver?
Last edited by ashdodmiracle on Wed Mar 30, 2011 1:57 pm, edited 2 times in total.
ashdodmiracle
Re: TBS 6921 v23 problem with saveral transporders.
Postby steven » Tue Mar 29, 2011 3:10 pm
Sorry for the problem you have met,you can contact our support,at [email protected] and give your detail information,
we can give you a RMA service for you.
Postby ashdodmiracle » Wed Mar 30, 2011 2:26 pm
Last update:
I tested again &
For now only one transporder is issued
Also (maybe it can help)
13E = 12034.00 V 27500 3/4 QPSK work ok.
TBS6922, TBS6923. 4W, 4.8E, 9E, 13E, 36E, 53E, 75E.
Previous cards: TBS8910, TBS8920, Qbox(ii), TBS6921
ashdodmiracle
Postby Derrick » Wed Mar 30, 2011 6:37 pm
Maybe your reception is poor or there's something wrong with the cables/connectors. What were your readings with the 8920?
My 8921 shows 98% quality for 5E, 12672H, 3300
Derrick
Postby ashdodmiracle » Wed Mar 30, 2011 8:52 pm
Derrick wrote:Maybe your reception is poor or there's something wrong with the cables/connectors. What were your readings with the 8920?
TBS8920 also shows 98%. It depends on device driver settings, it different for different devises.
ashdodmiracle
Postby ashdodmiracle » Tue Apr 12, 2011 11:39 pm
Additional issued transporders are found.
Amos 2/3 at 4.0°W Knesset Channel = 11625.00 V 3000 3/4 QPSK lock & scan, but find another channel instead.
I scaned this (11625.00 V) freq. & it find channel called METV instead, which by lingsat placed at 11630.00 V
So i tried to scan 11620.00 V to find a Knesset Channel, but nothing. At the end I managed to find it at 11622.00 V & 11623.00 V.
Despite a luck to find it, it still work very bad, card is able to lock it only 1/5 times (maybe because it placed between 11622.00 V & 11623.00 V), but when locked it work ok.
Looks as driver mistakes when translate freq (Freq. is shifted).
For instance: TBS8920 & QBOX-S2 work ok & find Knesset Channel at 11625.00 V
ashdodmiracle
