TBS6284 Linux Kernel 3.x drivers?
Postby bergqvistjl » Tue Dec 20, 2011 6:32 pm
Hi, Could you provide me with links to the most up-to-date versions of the DVB-T and DVB-T2 Drivers for the TBS6284 Quad DVB-T2 card, that work with the Linux kernel v3.x? I'm just getting a bit lost on your downloads page and am worried that I might download the wrong version.
Also, I have a query regarding the split dvb-t/dvb-t2 drivers.
As there are 4 tuners on my card, is it possible to install both dvb-t2 and dvb-t drivers (i'm not sure how it works really, if you could explain that would be great) and then have two of the four tuners appear as DVB-T and the other two appear as DVB-T2 in the system, or does it not work like that?
Thanks.
bergqvistjl
Re: TBS6284 Linux Kernel 3.x drivers?
Postby bergqvistjl » Wed Dec 21, 2011 6:49 pm
Can anyone help please?
bergqvistjl
Postby bob » Thu Dec 22, 2011 9:42 am
We keep developing combo linux driver for DVBT/T2,maybe will finish in next month.
Regards!
bob
Postby bergqvistjl » Thu Dec 22, 2011 2:00 pm
Can you give me the links for the latest drivers that you have at the moment for both dvb-t and dvb-t2 for this card, even if they are seperate? Thanks
bergqvistjl
Postby cody » Thu Dec 22, 2011 8:27 pm
bergqvistjl wrote:Can you give me the links for the latest drivers that you have at the moment for both dvb-t and dvb-t2 for this card, even if they are seperate? Thanks
latest dvb-t: http://www.tbsdtv.com/download/common/l ... 111118.zip
latest dvb-t2: viewtopic.php?f=52&t=2285#p9186
BTW, what you want, i.e. on 6284, because you have so many tuners available there, to make one of the tuner cans exclusively dvb-t and the other dvb-t2 is possible, but it will requires changes in the driver code that you can't do by yourself - i can't promise, but if i find spare time, i will post here such driver for 6284 in the next days, but otherwise, as 'bob' mentioned next month there will be driver that merges dvb-t/dvb-t2 drivers together and any of the tuners will be able to lock to both without need to change the driver.
Postby bergqvistjl » Thu Dec 22, 2011 9:34 pm
That would be great if you could do that (I guess for a quad tuner, 2 for dvb-t and the other 2 for dvb-t2) :)
bergqvistjl
Postby bergqvistjl » Thu Dec 22, 2011 10:10 pm
Also, regarding the current DVB-T mode drivers, is the .ko module file all I need for the system to recognise the card? If so, what else does the Makefile in this particular zip build?
bergqvistjl
Postby bergqvistjl » Mon Dec 26, 2011 9:20 am
I should add that while the DVB-T drivers work correctly, I can compile the DVB-T2 module, yet it does not work, I get the "frontend initialization failed" error when the module loads on startup, and no cards are found.
bergqvistjl
Postby bergqvistjl » Fri Jan 06, 2012 12:11 am
Please get these spammers off the site.
bergqvistjl
Postby bergqvistjl » Sat Jan 14, 2012 11:04 pm
Has there been any update on the Linux Drivers yet?
bergqvistjl
