issue with usb5922
issue with usb5922
Postby andysaed » Tue Jan 24, 2012 3:58 am
hello...
i have been so much problem with my new and lastest dvb card-- 5922 usb!!..
at the first times...i had bluescreens..
but after the latest versions of its driver that came out....my issue has changed to another problem...i have no any blue screen signs now!.but...when im using..tbs ip data...for satlite internet..or watching tvs....(almostely on tbs ip using)
my windows 7 os hangs up.after 2 or 5 minutes that i cant reset my notebook...and forces me to power it off by pluging off.
please....take for me..a way...to slove this
...tanc.
andysaed
Re: issue with usb5922
Postby steven » Wed Feb 01, 2012 5:14 pm
Hi andysaed
Please have a check of your email,I have send you a reply.
Postby andysaed » Tue Feb 07, 2012 6:27 am
hello
best tanx for reply
now i have another porblem....when i dont use tbs(means none of aplication or program that belongs to tbs5922) , windows alarms like the alarm saying your external hardware has plugg off..
means tbs gets off and on auto
andysaed
Postby steven » Tue Feb 07, 2012 2:28 pm
Hi andysaed
It is likely that your USB linker to your computer is instability.
Would you mind have check and try again. :)
Postby andysaed » Wed Feb 08, 2012 6:25 am
i checked it. everytime a new version comes to the site
it proves that the problem is the software not the hardware.
andysaed
Postby Campus » Thu Feb 09, 2012 6:38 am
I have exactly the same problem. One 5922 runs fine. A second 5922 stops DVBViewer on almost every channel change. Then I have to reconnect the usb device, reboot windows 7 and rerun the detect new hardware wizard because after the reboot windows is unable to initialize the device.
Campus
Postby auxius » Mon Feb 23, 2015 10:50 am
I also have a weird issue on my 5922SE
viewtopic.php?f=44&t=9340
Mine does not BSOD and initialize problem on the device i tried 10 n 1 and a 4 in 1 Diseqc but still the same having issue will LOCKING a satellite, tried it on Windows 7 64bit and 32bit the issue still there. Sometimes other port satellite works but other port works. But on my DM800se it works 100% without problem. Also there are time on windows 7 32bit my keyboard hitting on it's own TAB and ENTER keys at the same time i can't LOCK a signal on every satellite. I hope it's not a hardware defect i just order this on buydvb last week :-( The last time i get a 100% working after installing a Windows 7 32bit clean install driver, dvb dream and EBS. I think the last time is i installed dvbviewer which i can't setup it well.. after a restart i can't get a LOCK. I tried to uninstall DVBViewer but still no luck..But on my windows 7 64bit it's very rare to get a LOCK and also not all satellite if ever i get a chance to LOCK.
I hope there will be a driver update soon
Thanks cheers.
auxius
Users browsing this forum: Google [Bot] and 1 guest
