6920] config remote for DVBviewer & DVbdream
Postby magictails » Thu Jun 24, 2010 7:34 pm
hello
i have buy a TBS 6920 with remote IR
in win 7MC with latest drivers remote it's looking by windows and ok
but in dvbviewer pro i tick winlirc but nothing works , how to set up remote TBS ?
for my ss2 i have a file : default ts35.remote in C:/ dvbviewer /remote/default ts35.remote
for DVbdream i tick winlirc but not works i look a config file for TBS 6920 for winlirc
thank for advance
htpc coolmaster 250
Athlon 64 x2 4000+
asus M2A VM HDMI
2 x 1 go dual channel pc 6400 G Skill cas 4
Win 7
dish 9e 13e 19e 28E
tbs 6920 pci-e
SS HD 2 pci
SS 2 pci
5.1 phillips
magictails
Re: 6920] config remote for DVBviewer & DVbdream
Postby magictails » Thu Jun 24, 2010 9:30 pm
exemple du fichier que je recherche ou si vous avez les valeurs a rentrer pour la 6920
merci
Code: Select all
 # Please make this file available to others
# by sending it to <[email protected]>
# this config file was automatically generated
# using lirc-0.8.4a(default) on Sun Aug 30 19:33:29 2009
# contributed by
# brand:                       ./test
# model no. of remote control:
# devices being controlled by this remote:
begin remote
  name  Nova-HD-S2
  bits           13
  flags RC5|CONST_LENGTH
  eps            30
  aeps          100
  one           915   854
  zero          915   854
  plead         951
  gap          112860
  toggle_bit_mask 0x800
      begin codes
          OK                       0x17A5
          Left                     0x1796
          Right                    0x1797
          Up                       0x1794
          Down                     0x1795
          Power                    0x17BD
          Go                       0x17BB
          TV                       0x179C
          Videos                   0x1798
          Music                    0x1799
          Pictures                 0x179A
          Guide                    0x179B
          Radio                    0x178C
          Back                     0x179F
          Menu                     0x178D
          Volume+                  0x1790
          Volume-                  0x1791
          Ch+                      0x17A0
          Ch-                      0x17A1
          Mute                     0x178F
          PrevCh                   0x1792
          Pause                    0x17B0
          Play                     0x17B5
          Stop                     0x17B6
          Next                     0x179E
          Prev                     0x17A4
          Forward                  0x17B4
          Rewind                   0x17B2
          0                        0x1780
          1                        0x1781
          2                        0x1782
          3                        0x1783
          4                        0x1784
          5                        0x1785
          6                        0x1786
          7                        0x1787
          8                        0x1788
          9                        0x1789
          Red                      0x178B
          Green                    0x17AE
          Yellow                   0x17B8
          Blue                     0x17A9
          *                        0x178A
          #                        0x178E
      end codes
end remote
magictails
Postby cody » Fri Jun 25, 2010 9:36 am
hello,
in Windows 7 TBS remote control is installed as VHID (Virtual Human Input Device) device, which means the remote control is acting like virtual keyboard.
DVBViewer works with TBS remote control in similar way like Windows 7 Media Center - you don't need to do anything special like activating WinLIRC like you tried, because of the VHID support and you can test if DVBViewer is receiving events from the remote and even change the key settings with going to "Settings -> Options -> Input" in DVBViewer.
maybe, what you are missing for DVBDream is to copy "bda.dev" file that is found on the installation CD of your TBS card to "Devices" folder under the DVBDream installation folder.
in any case TBS remote control works in both DVBViewer and DVBDream and if the above doesn't help you will need to give me more details, which will help me to further assist you.
regards,
Postby magictails » Fri Jun 25, 2010 3:50 pm
hello
for win 7 it's ok but how change the button fonction , if possible
for dvbviewer it's works i test a change button fonction
i use a BDA device 2.50 in DVBdream 1.5c in /devices
work to BDA.dev scartman 1.08 tested and ok
it's ok after set p button in win lirc setting of dvbdream 1.5C
today tested prog DVb pro 6.42
saturday test on ubuntu lucid 10.4 with lirc
i look for the file config for linux lirc 10.4
http://lirc.sourceforge.net/remotes/
what it a values " gap " for manuel learn in lirc
exemple :
name Nova-HD-S2
bits 13
eps 30
aeps 100
one 915 854
zero 915 854
plead 951
gap 112860
thank
magictails
Postby cody » Mon Jun 28, 2010 9:29 am
for ProgDVB you will probably need to install device module from the installation CD of TBS 6920.
infra-red remote controller on TBS 6920 card is build in cx23885 chip and there is an effort about code that supports cx23885 build-in remote controller in Linux:
http://linuxtv.org/hg/~awalls/cx23885-ir
as far as i know the above code is almost ready, but still not finished.
